another crossgrade problem (with editbox)
Posted: Wed Jan 02, 2013 9:46 pm
by tester
Because this is crossgrade problem between SM and FS (3.0.1 Snowflake) - created here:
http://synthmaker.co.uk/forum/viewtopic ... 734#p90734
Schematic works fine in SM, but when loaded to FS - editbox issue pops up. I thought that this might be triggers related problem, but as you can see on inter-used second editbox - triggers seem to work fine (i.e. values are changing). So this is probably display problem within editbox itself.
Or maybe this topic could be solved in different way?
It starts to bother me a bit, because each time I must re-create OSM from scratch.
