Slower Largescope
lalalandsynth
Re: Slower Largescope
Post by lalalandsynth »
This is all kinds of weird. Did this work perfectly for you ?
Maybe I am just misunderstanding this and it should not start at the beginning of the scope window ?
That would explain a lot?
I hit play and it shows up here .
weird 1.jpg (38.93 KiB) Viewed 13485 times
I hit play again and it shows up here.
Weird 2.jpg (36.26 KiB) Viewed 13485 times
Wassaka
Post by Wassaka »
It works well for me. I made a system which when the song is played, resets the scan, causing it to be drawn as soon as the beat starts ... But this system requires DAW information ... I tested it in FL Studio and it works perfectly ...
Anyway I did a second version with some changes. Let's see if this works for you.
Meter Tempo Synced-V2.fsm
(572.13 KiB) Downloaded 959 times
lalalandsynth
Cool will test , to be clear when you say drawn when the beat starts , that means its drawn at the start of the window , far left ?
lalalandsynth
The "problem" for me is getting it to start at the beginning of the scope window.
It is not clear to me if it should do that and just not working or if its designed like this ?
Sync scope.jpg (57.86 KiB) Viewed 13468 times
lalalandsynth
Still trying to get this to work , but using this approach I cannot get the scope to start at the beginning of the scope window. Basically what I want to achieve is when looping say 2 bars in the daw it will show 2 bars of waveform.
So not a scrolling display and one where it starts drawing at the beginning of the window.
