Bus Extract prim problem: Not updating channel name..
Re: Bus Extract prim problem: Not updating channel name..
Ooh yes
I never saw that before but you’re right; I get the same and I’m also using 3.08.1 too.
That’s unexpected behaviour for me but I can see some logic I think. The poly to mono prim expects to be at the very end of a poly signal chain, so it can sum together all parallel (hidden) voices into blue mono. If you then try to add on another path, the poly to mono won’t be able to sum what you just connected, since you’ve increased the poly signal path beyond the prim’s reach.
I think the link needs to be released first so the schematic can re-compile before you make a different route. But it’s all black magic to me, so one has to guess and make assumptions. Interesting though.
