Page 2 of 2
Re: Delaying freely in range of 1 to 44 samples
Posted: Sun Mar 06, 2016 10:14 pm
by Perfect Human Interface
Wow neat, thanks Martin!
Which method does the stock interpolated delay use?
I don't mean to hijack (although Tulamide may have gotten what he wanted already?) but I'm working on a project that uses interpolated delay for time-based distortion/detuning and was wondering what kind of properties could exist within the delay itself. The stock delay sounds fine to me but could something else work even better?
Interpolation Methods
Posted: Mon Mar 07, 2016 9:50 am
IIRC the (interpolated) stock delay is allpass.
Allpass Interpolation: Best for slowly varying Delays like in a Chorus
Linear Interpolation: Best for fast random access like in a pitch shifter
Lagrange Interpolation: Best for random access with high fidelity like in a pitch shifter
Posted: Mon Mar 07, 2016 9:26 pm
Wow, Martin. You never cease to amaze me!
Posted: Mon Mar 07, 2016 9:33 pm
by Tronic
Martin, as always, a big thank for this.
I have a question regarding the implementation of the Lagrange interpolation,
what type of equation you used?
I'm trying to deduct it from assembler, but the optimization makes me harder to reverse the code :D
Posted: Tue Mar 08, 2016 12:09 am
Tronic, I provide this link although you probably know what Lagrange interpolation is. As to the implementation, I am storing 4 consecutive samples per quad word mem entry to minimize r/w access. So at a given instance, the current sample would be in SSE channel 0, the previous sample in channel 1 and so on. Then I use some shuffling and I think also SIMD to some extent to efficiently evaluate the Lagrange formula. I usually keep a code version for documentation but in this case it is not pssible.
Posted: Tue Mar 08, 2016 8:20 pm
by Youlean
Here you can see different implementation of interpolation... I think that this schematics was made by Exo...
Posted: Thu Mar 10, 2016 6:08 am
by Tronic
Thanks guys,
I just wanted to compare my Lagrange implementation,
because I get the same results, but I have a different coefficient from yours.
So I was wondering what kind of approximation you used for the coefficients of the polynomial.
In case, if you are interested to compare it to, I will post the code, but not optimized. :)
