Page 2 of 2
Re: How to retrigger a float (out) with same value?
Posted: Mon Dec 28, 2015 9:32 pm
Nowhk wrote:
tulamide wrote:Create a boolean. Connect the boolean output of the "Is playing" prim with the boolean. Everytime you stop and then start again, the boolean should switch to false and then back to true. Is it so?
Yes it is.
tulamide wrote:Create a second float, set it to 0.5, but don't connect it to the controller prim. Stop your DAW. Now remove the links to the controller's value input and connect the second float to it. Does "fruity send" switch back to 0.5?
No it doesnt.
tulamide wrote:You should report it as a bug then.
If yes, it might just be a timing issue and the trigger might just be delayed to work. But first check all the above.
Ok so its the Controller prim the problem. Where do I report it as bug?
Ah, too bad! I hoped it would just be a timing issue. But it seems that the controller prim is ignoring any triggers if the new value is the same as the last value.
On the front page of this forum you can read this:
"If you have a problem or need to report a bug please email : support@dsprobotics.com"
It will hopefully be corrected soon.
Posted: Tue Dec 29, 2015 11:00 am
by Nowhk
Ok, sent a message! Thank you!
