Perfect Human Interface wrote:You're not quite right. What you're saying would be correct if it was just the reciprocal (as in my LFO). NOT true for the reciprocal * 4. If you multiplied by 4
and then took the reciprocal, it would be beats (but still only true if the time sig is 4 beats per bar). These are not the same thing!
tulamide wrote:The only "1" there is, stands for 4 bars. Now just calculate: how many quarters fit into 4 bars? Yes, 16. And if you look at the value for "1/4" you'll be surprised. It reads 16! Just as expected
That's not "16" for 1 bar, that's "16" for 1/4 bar.
4 bars = 16 beats
reciprocal of 4 = 1/4; 1/4 * 4 = 1
1/4 bar = 1 beat
reciprocal of 1/4 = 4; 4 * 4 = 16
So it's not representing beats. It's not representing anything except the reciprocal * 4.
You're missing the point. I clearly said that the speed value is a relative value that's referring to 4 bars as 100% (number 1). All other values are then relations to those 4 bars! A 4-bar-package is 1, so a half 8-bar-package fits into one 4-bar-package, ergo 0.5. A half-note-package fits into a 4-bar-package 8 times, ergo value 8. A 1/32-note package fits into a 4-bar-package 128 times, ergo value 128.
Forget about the 1-bar, the base here is 4-bars! You really make it too complicated
Nubeat7 wrote:ok, i'm really confused now too, so please tell me what a bar is
lets say we use 4/4
is a bar 4 quater notes? or 4*4 quater notes?
sadly i'm not a musician as i always understood it a beat is 4 quater notes and a bar is 4 beats (16 quaternotes)
so if we use 3/4
a beat would be 3 quaternotes and a bar would be 12 quaternotes
i'm right with this ?
because when not my calculation would be wrong to multiply num and denom to get barlenght!?
and how is it with 7/8?
There are quite a few names and they all mean something else, depending on the situation. For example, the term "beat" is known in relation to a metronome. It does x many beats per minute. What is meant by that is that it does signalize the beginning of a quarter note per beat. So 120 bpm means 120 quarter notes per minute.
But a quarter note fits into different time signatures. The well known 4/4 time signature means 4x a quarter note. So if you play 4 quarter notes, you've played one bar.
A bar is one cycle of the time signature.
In the time signature 3/4 you only have 3 quarter notes per bar. And in the time signature 6/8 you're playing 6 1/8th notes per bar. While the last example mathematically is the same as 3/4, a musician counts both differently (for 3/4 it's one, two, three, one two three, etc., for 6/8 it's one, two, three, ..., six, one, two, three, ..., six, etc.)
To get this all together, one would take the bpm and the time signature. Example:
Time Signature: 4/4
BPM: 120
means 120/4 = 30 bars per minute, or 60seconds/120beats = 0.5 seconds per quarter
Time Signature 6/8
BPM: 120
Two 1/8th are one quarter, so 240/6 = 40 bars per minute, or 60/240 = 0.25 seconds per eigth
etc.
PPQ means pulses per quarter. So this is a relative number, because the length in time of a quarter note differs depending on the bpm. In the above examples, let's assume a ppq of 960 (that number is dependant on the host daw's capabilities and the host user's decision). Now the resolution of a quarter note would be represented by 960 ticks (pulses) within 0.5 seconds, a tick per (0.5 /960) = 0.00052s
