Trigger Timing
Re: Trigger Timing
Wow, thank you very much Trog. I guess looking at the green conversion it wasn't so ridiculous as I thought. And yes, it works just fine. I'll study the Ruby "tutorial" when I have time later. :) Above and beyond as always... I appreciate it.
Re: Trigger Timing
You're welcome. :D
Re: Trigger Timing
TROG ... you mentioned naming of INPUTS on the RUBY module, and cautioned about punctuation and spaces in the name. Now you have me wondering ... :shock:
There have been, hmmmm .... several times I have 2 INPUT variables that have a Name and a Number.
I've been trying to keep a simple convention, using something like this:
name
name#
? Is there a way to test if a variable name [label] is not acceptable ? :?
Re: Trigger Timing
RJHollins wrote:? Is there a way to test if a variable name [label] is not acceptable ?
Something every Ruby programmer needs to know; so I've posted the answer HERE so it's easier to find.
Short version of the answer - yes, name (letters of either case) followed by digits is always acceptable. And having a convention is a fine idea - saves a hell of a lot of skipping around the code trying to remind yourself what you called things!
