min/max filtering (array)
Re: min/max filtering (array)
Tronic wrote:array = [-1,0.0,90,50,100,150,200]
min = 0.0 ;
max = 100 ;
(array.map {|v| (min..max) === v ? v : nil }).compact
smart! already met the "case equality operator" few times, but never knew where/how to use..
billv wrote:I still can't get a result from this...Code: Select all
def event i,v
if i == 0 then
minVal = 0.5
maxVal = 1
a = @txt.map{|item|item*maxVal-minVal+minVal}
output 0,a
watch this thread, trog explains the correct methode there..
viewtopic.php?f=3&t=1760
I see I opened a headache maker.
Posting schematized ("green prims" compatible so to speak) idea provided by Tronic, in case someone with my (equall-or-less)skills looks for such thing.
Seems to work fine, and looks elegant. Thanks!
- in-min-max-range.fsm
- (449 Bytes) Downloaded 879 times
i think a combination of tronics version and mine would be the shortest and fastest
i`m @ work, so not tested
output @yourarray.keep_if{|x|(min..max) === x}i`m @ work, so not tested
Nubeat7 wrote:i think a combination of tronics version and mine would be the shortest and fastestCode: Select all
This break the result of array if the next value not match the min/max range.
Tronic wrote:Nubeat7 wrote:i think a combination of tronics version and mine would be the shortest and fastestCode: Select all
hmm strange i tried it here:
http://www.compileonline.com/execute_ruby_online.php
array = [5,1,3,4,1,6,7,8,9]
array.keep_if{|x|(2..7) === x}
puts array;and it puts:
5
3
4
6
7
so it shoul be right?
Yes work
sorry, mistake in my testing.
Nubeat7 wrote:watch this thread, trog explains the correct methode there..
...seems he saw similar issue...all good....thanks
