Array problem in Ruby - am I missing something??
Re: Array problem in Ruby - am I missing something??
Ouch.. when I reopened this file now, I get an error:
undefined method for 'each' nil........
Then I just removed a comment from the code the error disappeared.
Ah, yes I've seen that before.
Ruby calls 'init' when FS starts, or you load a schematic - but that happens before the 'green' schematic starts, and before the values saved with the file get read in. This means that some input values may not be defined when 'init' runs for the first time - your '@px', '@py' and '@width' variables in this case.
When you edit the code in any way, 'init' gets run again to make sure the code is refreshed - and this time will always run properly because the input values are now all present and correct.
So 'init' should only be used for code that doesn't have to read the input values.
Simplest way to deal with it is this...
Give 'init' a different name, e.g. 'makeData' - so that there's no 'auto-run' at startup. Then call 'makeData' before refreshing the screen to make sure that the values are all defined.
On its own, that works, but re-making the array for every redraw will use up CPU for no reason, redefining the same things over and over.
To stop that from happening, you can put in a test to make sure that your new 'makeData' method only runs once...
This works because of the way that Ruby decides true or false for 'if' and 'unless' statements...
'nil' or 'false' => false
Any other value => true
So, if @buttons has been defined already that counts as true, so 'makeData' won't run - if it isn't defined, it will return 'nil', and 'makeData' gets called.
NB) Something to be careful of !!..
Inside Ruby, the number zero counts as "there is a value, and it's zero" - so zero evaluates as true. Not like 'green ' bools' where zero is false. So if you want zero to count as false, be sure to test for it explicitly.
makeData unless @buttonsThis works because of the way that Ruby decides true or false for 'if' and 'unless' statements...
hm... a lot to digest
for now i just removed the def init method
it solved as you told the update problem. also the error i got due to the late greens as you also said
thank you
thank you
This code makes rows for the 'button_values[:y] ' but I am strugling to understand/write the code for 'button_values[:x]'. I can not make it wrap the index number back to zero at each row as desired. Sorry for all the noob Q's coming in a row her the last days.
arrays=@arrayw*@arrayh-1
@buttons = Array.new
(0..arrays).each do |index|
button_values = Hash.new
button_values[:x] = index*(@width+@px)+@px #NEED TO CHANGE THIS
#So I get the rows wrapped, kind of like:
# button_values[:x] = index-(index>@arrayw)&@arrayw #ie index 0-12 would be index (0-3)*3
#I also see that doin this kind of operation on 'index' will screw up other things.
#But you get the idea?
button_values[:y] = index/@arrayw*(@height+@py)+@py
button_values[:state] = 0
@buttons[index] = button_values
Here you have the fsm file. I would love to get some help in this project so any one please feel free to use it for your own projects and modify it as you please. Credits so far go to (mostly) Trogluddite and some me.
- Button_Array_v2.2.fsm
- (2.82 KiB) Downloaded 1185 times
Looks like you need a modulus...
Assuming that you are numbering left->right then top->bottom, you have the y right - just an integer divide. What you need for the x position is the remainder from that divide - the 'left over' part of the result. And that's what he modulus function does.
The symbol is '%', and you place it in the maths just like a divide - here's an example how you would use it in your code...
No need to apologise - I have asked many myself over the years!
One of the best things about SM was the amazing collection of modules and code built up on the forum - hundreds of tools, effects, code routines and useful examples - and that's probably the biggest thing missing from FS at the moment, particularly for the new stuff like Ruby. The dev's wouldn't get any updates done if they tried to show an example of everything possible - so I'm up for sharing as much as possible, and throwing mad ideas about, so we can build up the forum to be as good as the SM site (though I will never forget she was my first true love!
The buttons are coming along beautifully, it's a really nice design, and plenty of customisable options too - it will be a very useful module I think. "Radio buttons" are one of those things that come up regularly on the forums - now you won't need to build anything - just type in how many you want, and all done!
If we could get a good collection of nice GUI stuff like this together, maybe we could get the dev's to make it one of the official "module packs" for the main download section - so that all the good stuff doesn't get buried under hundreds of threads.
button_values[:x] = index % @arrayw * (@width+@px)+@px # Modulus
button_values[:y] = index / @arrayw * (@height+@py)+@py # Dividetor wrote:Sorry for all the noob Q's coming in a row her the last days
Great
So far so good:
So far so good:
Still dont quite understand the alternatives to 'def init' in the first code part. I have made some attempts like just replacing 'init' with 'makeData' andwrap the 'def init' inside a 'def event' but I have not yet succeded and I have made some attempts to add a redraw at different places with no luck.
Guess I still have a LOT to learn
I am trying to change the active mouse area from a circle to a rounded rectanle that follow the shape of the buttons. But my try gives an error. I tried to search google for an answer but no luck.
The original part of the code:
My attampt to change the shape:
NoMethodError: (in method 'isInMousePoint'): undefined method 'addRoundRect' for #<GraphicsPath:0xad5f1ec
I presumed the method addRoundRect was sort of like drawRoundRect. But it is not.
I am also looking for a soultion for a second button state that is controlled by an external array (info from a sequencer) so the user can see the beat position. Yes, I am building this because my goal is a pattern sequencer
Atm the seq state input is an Int array but in time it will be a ruby connection from an actual sequencer that I think also will be handling the preset functionality when I get there (somewhere in the year 2034 or so).
Problem I have met so far is that if I add a state2 in the first part of the code state 1 gets reset each time i click a button. State2 then only update when I click a button or do a change in the scematic.
Must admit I do not fully understand the event and redaw systems in ruby
def clickedButton?(x,y,button)
button_x = button[:x]
button_y = button[:y]
button_area = [button_x,button_y,@width-2*@frthick,@height-2*@frthick]
circle = GraphicsPath.new
circle.addEllipse(button_area)
return circle.isVisible([x,y])
endMy attampt to change the shape:
button_area=[button_x,button_y,@width-2*@frthick,@height-2*@frthick]
activeArea = GraphicsPath.new
activeArea.addRoundRect activeArea,button_area,@round
return activeArea.isVisible([x,y])
endNoMethodError: (in method 'isInMousePoint'): undefined method 'addRoundRect' for #<GraphicsPath:0xad5f1ec
Here is the fsm file:
