how to combine
tester
how to combine
Post by tester »
I have two ruby instances, that share the same signal flow (and loop flow), just create different output. While one is responsible for generating randomness, second one - is responsible for filling everything (everything not excluded) with specific input value. How to combine (and optimize) them into single ruby instance? (I ask, because there are some performance issues with too many ruby instances within 1 schematic).
how to combine.fsm
(881 Bytes) Downloaded 908 times
Tronic
Re: how to combine
Post by Tronic »
:arrow:
how to combine_Tronic.fsm
(859 Bytes) Downloaded 905 times
tester
Re: how to combine
Post by tester »
Thanks. However - can these input triggers be separated (to 2 inputs)? So that ruby performs either randomization or cross copy, but not both at the same time?
TrojakEW
Re: how to combine
Post by TrojakEW »
LIke that?
how to combine_Tronic_2trig.fsm
(885 Bytes) Downloaded 889 times
tester
Re: how to combine
Post by tester »
Yes, thank you.
