Stream Router.
joejoe
Stream Router.
Post by joejoe »
I need a stream router.
In reaktor you have a router that you use with a comparator(i.e. >,<,>=,=<, etc). to send the signal to two possible routes.
There doesn't seem to be one in FS. Further more if I use the DSP I wont be able to input Boolean.
Do I have to build a router?
CoreStylerz
Re: Stream Router.
Post by CoreStylerz »
You have the stream comparators >,=>,<,<= search stream on the search bar.
PM me if you are interested.
tester
Re: Stream Router.
Post by tester »
I think the question was about inputs/outputs, boolean ins paralel to signal ins. Or?
Anyway, if so, I'm not sure if this is handled through automation routines (and thus - preset system) or requires additional named ins open on front of the module.
nix
Re: Stream Router.
Post by nix »
routers.fsm
(2.38 KiB) Downloaded 1058 times
Here you are Joe, hope this is what u need.
If you have any questions-shoot
joejoe
Re: Stream Router.
Post by joejoe »
Nix,
Yes those mods are exactly what I need thank you so much!
streamboolin was the main thing I was missing. doh :roll:
joejoe
Re: Stream Router.
Post by joejoe »
Actually I misspoke. I need a bool input and stream input and two stream outs one for a false condition and one for a true condition. I still don't fully get this DSP code with if statements.
nix
Re: Stream Router.
Post by nix »
multiplexer.fsm
(1.11 KiB) Downloaded 1053 times
I guess this is called a multiplexer.
No problems to try and do some more alterations if it isn't the mod u need.
I think with the if, it's a bool.
either true or false.
If true it will deliver the &ed value
joejoe
Re: Stream Router.
Post by joejoe »
Thanks Nick that seems to work!
Re: Stream Router.
the router could be done simpler putting all into "or" statements ("|") to avoid all the extra variables and the adding at the end, just take care to put the whole if statement in braces to work correct.
routers.fsm
(1.12 KiB) Downloaded 1060 times
nix
Re: Stream Router.
Post by nix »
thanks for that NuBeat 8D
will change the code in my synth to this neater logic.
I originally was using the integer indexed router
to modulate a formant filter.
ps- You're welcome Joe, hope the environment gels with you.
The 2 floats in the multiplexer can be deleted,
just didn't notice they got left in.
