Load / Save any File to Schematics
Hello!
I experimented with ruby and binary files - And i got it managed to store any files eaven binary things to the schematic by saving each single byte with ruby.
So packing some files to the VST may now be no problem anymore
Regards
C.Hackl
Regards
C.Hackl
- load&save any File.fsm
- (291.94 KiB) Downloaded 1467 times
- trogluddite
Re: Load / Save any File to Schematics
This becomes even more powerful when you use the Array.pack and String.unpack methods.
These let you turn any kind of numeric data into String form for saving, and back again - in this case the term "String" is used in its most general sense; a sequence of bytes, not necessarily interpreted as being characters.
For example...
...gives you a String byte-sequence that encodes the array of float numbers (single precision in this case).
And...
...will get you back to the original array.
Also, check out the Marshal class - even more powerful!
This has methods that allow you to turn almost any Ruby object into a serialized String and back again - including even Arrays etc. nested many levels deep.
You can even make this work for your own custom classes of object if you define the correct 'load' and 'dump' methods in your new class - all you need is some way to turn your object into a string and back again (possibly by the Marshal methods of any component objects).
There are a few exceptions where this doesn't work - for example many of the FS GUI objects lack the necessary Marshal methods, so, as yet, you can't easily save GraphicsPaths, Pens, etc.
For example...
byte_string = [0.123, 0.543, 1.462, 7.890].pack('F*')...gives you a String byte-sequence that encodes the array of float numbers (single precision in this case).
And...
my_array = byte_string.unpack('F*')...will get you back to the original array.
hashed_arrays = { "Array1" => [10,20,30], "Array2" => [40,50,60] }
File.open(my_file,"w"){|file| Marshal.dump(hashed_arrays, file)}
hashed_arrays = File.open(my_file, "r"){|file| Marshal.load(file)}You can even make this work for your own custom classes of object if you define the correct 'load' and 'dump' methods in your new class - all you need is some way to turn your object into a string and back again (possibly by the Marshal methods of any component objects).
I did an uppdate now:
I had some errors with load ans save state and corrected to the correct file dialog
Torg:
I sea what you mean - i also thought of that way for example combining files into one file with ruby.
There is only one thing why i have not done it jet:
I do not get this F....ING ZLIB running - to compress data
Update is in first post
Regards
Torg:
Regards
Hi C.Hackl,
I'm following along your thread here ... trying to continue learning.
I'm being help on a new file/data SAVE & LOAD routine. TROG posted the Ruby Marshal code which is absolutely great.
I don't want to interrupt your thread at all ... but I was looking at your post as I search for implementing some 'Directory Management' functions to dress out this Marshal routine.
Looking at your code, I see some sections of interest.
I've been using TROG's 'Save Load Application Data settings file' that has default directory locations, find if a file exists, and can create a Folder to store in.
I'm not confident in my writing of RUBY that would involve things like directories or creating folders ... don't need to tempt a disaster
I feel safer with GREEN. Yet was wondering if you had plans to have these type of functions for this module ?
sorry to interrupt ... thanks for your posts !!!
Ive just added now a Save Load for complet dirs and subdirs
Regards
EDIT- And i can not upload it ^^
EDIT2 - It got over 2MB so i had to delete the files inside -sorry
Regards
maybe the WAV data file is bulking up the filesize ?!?
If you save a file within a schematic - it will gow ^^
This is a normal natural Computer phenomenon
