key emulate
fixstuff555
key emulate
Post by fixstuff555 »
Hi all,
Anyone done any keyboard emulation with Ruby, and the Win32 api?
In particular, I'd like to send keystrokes to the windows keyboard stream using SendInput in API if possible.
Any ideas on how to do this?
I found this:
http://batchloaf.wordpress.com/2012/04/17/simulating-a-keystroke-in-win32-c-or-c-using-sendinput/, but its for C++. so I found this:
http://www.velocityreviews.com/forums/t821631-ruby-dl-sendinput.html
But its not functional the way its shown.. Any ideas on how to do this? I have attached the code I was testing, but I can't get it to work. I'm sure its something stupid.
key_emulate2.fsm
(617 Bytes) Downloaded 969 times
Tronic
Re: key emulate
Post by Tronic »
this is the code that I use.
:arrow:
# Ruby Key Sender by Tronic
require 'Win32API'
# http://msdn.microsoft.com/en-us/library/windows/desktop/ms646306(v=vs.85).aspx
MapVirtualKey = Win32API.new('user32.dll', 'MapVirtualKey', %w(i i), 'i')
# http://msdn.microsoft.com/en-us/library/windows/desktop/ms646310(v=vs.85).aspx
SendInput = Win32API.new("user32", "SendInput", %w(i p i), 'i')
# http://msdn.microsoft.com/en-us/library/windows/desktop/ms646270(v=vs.85).aspx
# http://msdn.microsoft.com/en-us/library/windows/desktop/ms646271(v=vs.85).aspx
INPUT_KEYBOARD = 1
KEYEVENTF_UNICODE = 0x0004
KEYEVENTF_KEYUP = 2
# Defined costant for Shift & Ctrl
# Add here the other special key you need
VK_SHIFT = 0x10
VK_CONTROL = 0x11
# Perform the operation hit for the specified key on the keyboard.
# Vkey Specifies an array of key code of the key that hit at the same time.
# For example, if you want to enter the t (lower case)
# keys_send (['T'])
# If you want to enter the T (upper case)
# keys_send ([VK_SHIFT, 'T'])
def keys_send(keys)
# convert key to integer unicode
key_conv= keys.map{|ikeys|
         case ikeys
           when String
           ikeys.unpack('U')[0]
           else
           ikeys
           end   }
wscans = key_conv.map{|vkey| MapVirtualKey.call(vkey, 0)}
vkeywscan = key_conv.zip(wscans)
keydowns = vkeywscan.map{|vkey, wscan|
         [INPUT_KEYBOARD, vkey, wscan, 0, 0, 0, 0, 0].pack('ISSIIIII')
keyups = vkeywscan.map{|vkey, wscan|
         [INPUT_KEYBOARD, vkey, wscan, KEYEVENTF_UNICODE|KEYEVENTF_KEYUP, 0, 0, 0, 0].pack('ISSIIIII')
         }.reverse
SendInput.call(keys.length*2, keydowns.join('')+keyups.join(''), keydowns[0].length)
def event i
   keys_send([VK_SHIFT,'K'])
MyCo
Re: key emulate
Post by MyCo »
kortezzzz
Re: key emulate
Post by kortezzzz »
THANKS,
and MyCo, please check your massage box.
fixstuff555
Re: key emulate
Those are awesome guys. Thanks a bunch :)
