RBJ Filters - Audio Biquad - RubyMaths
http://www.musicdsp.org/files/Audio-EQ-Cookbook.txt
Here is a Flowstone implementation and generalization of the RBJ Filters.
- IIR BiQuad.fsm
- (28.92 KiB) Downloaded 1451 times
- IIR BiQuad (RBJ).fsm
- (216.02 KiB) Downloaded 1454 times
- IIR BiQuad (RBJ and knobs).fsm
- (225.93 KiB) Downloaded 1472 times
Re: RBJ Filters - Audio Biquad - RubyMaths
Just in case you haven't seen it already:
viewtopic.php?f=3&t=1234
That's great. Thanks.MyCo wrote:Just in case you haven't seen it already:
For equalizing speaker drivers, like for battling against cone breakup in the high frequencies, most of the time you need a combination of LPF, BPF and HPF, for implementing a kind of refined notch.
In the deep bass end, most of the time a Linkwitz Transform (BassBoost/Equalizer) will exhibits the same need.
A simple shelving tone control (Bass/Treble) also requires that you combine the LPF, BPF and HPF outputs of a BiQuad.
