anyone have tdf2 filters?
- wlangfor@uoguelph.ca
Hi all I could'nt find tdf2 filters and wondered if someone has an example,
Thanks
Thanks
Re: anyone have tdf2 filters?
My post on Flowstone Guru is no longer accessible, so I repst it here.
The TDF2 filter topology has the advantage of using only 2 states hence CPU load is low. The main drawbacks are (i) truncation errors at low frequencies and (ii) instability against fast modulation. The ZDF topology solves both issues at little extra CPU load.
- Optimized-Biquad-Filters.fsm
- (19.97 KiB) Downloaded 902 times
Thanks Martin, that's very useful.
I'll use them quite a bit
