Error in user guide
francoisreme
Error in user guide
Hi folks.
I'm kind of surprised about these lines in flowstone user guide, and also with provided helper functions.
if we use a new [] we need to use delete[]. Could be serious memory issue, if you leak an array of size N at each function call...
// Delete previous array and reset pOut entry
if( pOut[x] )
delete *((int**)&pOut[x]);
pOut[x] = 0;
// Create new array (assume we have declared 'length' – add 1 for size at front)
int* array = new int[length+1];
- trogluddite
Re: Error in user guide
Unfortunately, the code examples in the FlowStone documentation and default toolbox items are often of a pretty poor standard. You're quite right of course, the C++ standard says that new[] -> delete is "undefined behaviour". In most compilers, it does work without leaking memory so long as the array contains only POD data types, as they have no destructors to call - so it's fortunate that the DLL API types are all POD (string arrays contains C-style strings which have to be freed manually)!
I've seen other coders do this for POD arrays, especially if they're regular C coders who haven't used C++ much. The compiler will optimise away destructor calls if they're not required, so there's no clever "hacky" reason to do it - it's really easy to get caught out by it if you change the array to contain objects, and it can get beginners into bad habits!
francoisreme
Didn't event know that (POD types) !
