Any info on Flowstone versioning?
snafu
Post by snafu »
Hi there,
it's been a while, and only recently I have returned to flowstone. In my download area it says 'YOUR UPGRADE COVER HAS EXPIRED'. I think I started with version 3.0.7, but I'm not sure though. I can download anything from 3.0 to 3.0.9beta, so I wasn't sure if it is actually the newest version. There have been a few issues with the version I used before, so I wanted to upgrade. So, I've been around here for a good two hours now, and now confusion kicks in:
- if I can download 3.0.8 (or any of the betas), which seem to be the latest versions, there's no need upgrading for me, isn't it?
- is Flowstone still updated? The latest version seems to date back to 2016 - or is it discontinued?
- or is this just all versions covered in my download area - are there any newer versions than, say, 3.0.9? I don't think so, according to what I found here in the forum, but than again, I might be wrong...
Thanks for any help that might sort things out for me,
cheers
snafu
Re: Any info on Flowstone versioning?
Welcome back on board Mr Snafu! :D
The best version to use at the moment is widely agreed to be 3.06 so you should be ok.
Ages ago I downgraded from 3.08.1 to 3.06 and never looked back. Faster and more stable you see, and fully compatible with 3.08.1 schematics and toolbox.
FlowStone 4 with x64 support is being developed and coming on really well, but it’s not worth paying for upgrade cover at this point because we don’t have a release date yet for FS4.
Please avoid the 3.09 betas at all costs; they are really buggy.
Have fun!
3.0.8.1 is supposed to have some ASM extensions compared to 3.0.6.
That’s new info for me Martin! :o
Do we know what’s been added? So far I’ve had no problems with anybody’s ASM code…
snafu
Post by snafu »
Thank you very much, Mr. Spogg :D
Flowstone is a really cool tool, and I came across many (with different purposes though), but Flowstone must be the most impressive one.
Thanks for helping out!
kind regards
snafu
@Martin
Thanks for that link. I guess I've been lucky with other people's ASM code then. So far. :?
Did you personanlly make use of any of these new opcodes?
If I get one that doesn't work for me I can always briefly re-install 3.08 I guess.
Spogg wrote:@Martin
I'm afraid I use them alll the time. Usually my schematics don't work with FS 3.0.6 but they don't crash either so it may not be obvious.
That’s quite a worry Martin. :?
Would it be safe to assume that if one of yours does work then it’s ok in 3.06. Or might it be that something can partially work?
Spogg wrote:If I get one that doesn't work for me I can always briefly re-install 3.08 I guess.
I wouldn't advise to go back to a version with issues (btw, the 3.0.9 betas are based on 3.0.8.1) just because Martin refuses to work with 3.0.6. He is also the one that regularly reports a lot of crashes with his version ;)
