Partial Voyetra emulation
Re: Partial Voyetra emulation
Thanks ! Be sure to read the 'Info' panel pop-up to get familiar with the several 'hidden' and alternate functions, especially in the Mod Banks.
Spogg wrote:CUSS?
Now I'm uncertain. Do you play on me, or did you really not understand it?
Contrast
User guidance
Symmetry
Spare use of colors
I highly doubt you don't know the second meaning...
I'm thinking of trying to make some of the text on Voyette a bit larger - is anyone having trouble reading any of it? I think most of you have larger displays than I do.
Gotta optimize that CUSS'ed GUI!
tulamide wrote:
Spogg wrote:CUSS?
No I really didn't see it. :oops:
Have pity on a senescent Vulcan who spent a long time trying to make something that fitted. :lol:
Poor old Spogg
k brown wrote:I'm thinking of trying to make some of the text on Voyette a bit larger - is anyone having trouble reading any of it?
It's fine for me, and I reckon it scales well with the front panel controls.
A pretty major (for some people) feature added - the joystick now accepts MIDI CC# 16 for X and 17 for Y, so it can be controlled with Yamaha SY22, SY35, and TG33; or any midi joystick with programmable CC outputs. This thing would be far more fun to play with an actual, physical joystick, and if it's a spring-to-center type it would be just like playing the Voetra's companion keyboard.
Also a few other tweaks and corrections.
https://ln.sync.com/dl/626f96b00/2vu6pr ... c-rkvsedfk
Off topic - what's with all this 'spam' that's showing up in the forum; no way to filter that junk?
Just added a couple key features that I overlooked - since this mostly emulates the Voyetra Eight's 'Layer' mode (a left/right pair of poly voices), the V-8's joystick output could be inverted for the left voice (the hardware had one voice panned hard left, the other hard right; here each has a pan control, so in the plugin, it's voice 'I' that has it's joystick output inverted). The hardware would only invert the X output because the Y was hardwired to pitch only, and not available in the Mod Banks. Here, the Y output can be disconnected from pitch and is available in the Mod Banks, and the X and Y outputs can be independently inverted to 'voice' 1's Banks.
Also, when in 'Layer' mode the V-8's right voice's LFO rate controls are synced to the left voice. So added buttons in 'voice' II to sync each of it's LFOs' rates to those in 'voice' I.
Guess I better call this v1.01 at this point.
Voyette SPT copy.jpg (176.09 KiB) Viewed 14892 times
