non-linear rescaling of arrays
Let say that I have array in range (0-1). I'd like to push it through nonlinear rescaling routines. Anyone experimented with it? Trog - I'm looking at your tools, but I see curves only for floats; did you experimented with that for arrays too?
Perfect Human Interface
Re: non-linear rescaling of arrays
I'd think you'd just use the loop component to draw each value of the array consecutively and apply math to it.
I'm not sure how it should work. Array is changing continuously (tick25). But I think I have another idea to test (individual float outputs).
- trogluddite
Yes, Human Interface is right, there's no 'bulk transform' component - you have to treat each element in turn.
Using the regular 'Integer Loop', that means LOTS of triggers, so this is something that Ruby is much better suited for.
Here's a "skeleton" Ruby block that you could use as a template...
