Gate to Amp. How do i do that?
lalalandsynth
Re: Gate to Amp. How do i do that?
Post by lalalandsynth »
Maybe check this thread.
viewtopic.php?f=2&t=13380
Halon
Post by Halon »
martinvicanek wrote:
Halon wrote:A lot of synthesizers have the option to switch from Envelope to Gate for the Amplifier, so you might use the envelope for other tasks (modulation).
You can keep the amp envelope and use another envelope for other tasks, no?
Yes but I would like to simulate a classic monophonic 1 envelope synthesizer.
lalalandsynth wrote:Maybe check this thread.
Will have a look thanks.
Spogg wrote:The MIDI to Voice and Voice to Poly prims open a channel when a note is pressed. While the channel is open (a note is sounding) you can switch on and off any signal you wish.
You must have a minimum of one envelope prim in the poly system. The prim tells the software when to close a poly channel.
When note-off happens the envelope prim has to be told to close the channel, otherwise each new channel opened will never be turned off and the CPU will rocket.
If that’s not clear I could maybe make a demo...
You have helped me a lot so il afraid to ask :oops: .. but could you?
nix
Post by nix »
Is this what we're after?->
env or gate3081.fsm
(29.88 KiB) Downloaded 984 times
Hope helps!
That's the kind of thing I had in mind Nix!
nix
Post by nix »
cool :)
IMO-It would work prolly without any envelope at all,
and just the gate to turn it on and off-
if u meant to intonate it mightn't Spogg mate
addendum--I thought it best to test. It's OK to use the gate and have no envelope in the schematic
nix wrote:
... It's OK to use the gate and have no envelope in the schematic
Hmmm... Seems I was wrong then. :oops:
Something to learn every day with FlowStone!
Halon
Post by Halon »
Thanks Nix, but for some reason i cant open your schematic.
This is true with other schematics I have downloaded feom you. :(
nix
Post by nix »
darn mate-
this is for FS 3081,
it really should open in it.
Here are images->
option 1_0.png (57.18 KiB) Viewed 17150 times
^this one doesn't use gate
option 2_0.png (59.46 KiB) Viewed 17150 times
^this one multiplies by gate
hope helps
Halon
Post by Halon »
I have the FL Studio version of SynthMaker/Flowstone. But thank you for the images. :)
nix
Post by nix »
No worries!
I'll keep your version in mind.
I'm only running Fruity 7 and 20 atm,
but maybe Image_Line will like the 64 bit version on FS-
and we can try to popularize it more
