QUESTION/HELP
QUESTION/HELP
Hello gang,
Say if I wish to change several knobs (2 or more) at the same time, what would be the best method? Thanks in advance for any and all help!
Later then, BobF.....
Re: QUESTION/HELP
Hi Bob
Do you mean change the setting or change the graphics?
Re: QUESTION/HELP
I think he means editing them at the same time? You need to right click and use the synchronize painter and sync them.
Re: QUESTION/HELP
Thanks guys!
Sorry, yes change setting.
Adamszabo, do you have an example. I have never used that feature?
Later, BobF....
Later, BobF....
Re: QUESTION/HELP
It explains everything in the manual very well! Check page 84 in the user guide
Re: QUESTION/HELP
Ok, there is misunderstanding, my bad. What I want is when you move one knob all the others follow. For an example, say I have 5 delays. When I move the delay time knob for number 1, I want 2,3,4, and 5 also to move the same amount.
Thanks again, BobF.....
Re: QUESTION/HELP
These might be called 'LINKED' knobs.
I've seen on forum, a 2 knob linked ... not seen 3+ ...
It'd be interesting to see a working example.
One example I tried to explore was linking several knobs to a 'Master' knob that would allow for 'relative' adjustments.
It got difficult when one of those knobs/faders hit a Min or Max before the others. How to retain the original value relationships. I was not able to resolve
Re: QUESTION/HELP
Maybe you mean something like this?
- link.fsm
- (120.37 KiB) Downloaded 1203 times
Re: QUESTION/HELP
YES, this is Perfect. Thanks, Adam.....
Cheers, BobF.....
Cheers, BobF.....
