[Ruby] How to call back from superclass to subclass?
You have a class for centered coordinates. It defines a setter method.
class A
def initialize
@x = 0.0
def x=(value)
@x = value
endA second class inherits A and uses x to calculate the top-left position.
class B < A
def initialize
@l = 0.0
def update
@l = @x - 2
endNow, to actually do the update, I have to wait for x to change. If that happens, update is called afterwards. And here's where it gets ugly. Implementation:
class B < A
def initialize
@l = 0.0
def update
@l = @x - 2
def x=(value)
super(value)
update
endI don't like that for two reasons:
1) defining x=(value) two times (I think it's called monkey patching) shouldn't be necessary in such an elegant language.
2) The update method in reality is a general updater, that not only updates @l, but some other variables as well. The superclass does not just host @x, but a lot of other variables. In effect, I need to define the setter two times for each of them, always with a call of update()
What I'm looking for, is a way to signalize the subclass, that a superclass method has been called, so that I can run update()
PSEUDOCODE!
class B < A
def initialize
@l = 0.0
def update
@l = @x - 2
def message_from_super
update()
endAny ideas?
Re: [Ruby] How to call back from superclass to subclass?
class A
def update;end
def x=(v)
@x=v
update()
return v
class B < A
def update
@l=@x-2
That is the simplest most elegant solution.
Alternatively, you may automate the monkey-patching by iterrating trough the parent's methods and declaring new method with the same name for each setter (name should match /^\w+=$/ or in english a nonzero-length word character (numbers/letters/_) string ending with "="). This has the added benefit, that it will also work with setter methods declared with attr_writer and attr_accessor methods. In the previous solution this would not be the case.
Note, you will have to update the specific ruby component for changes to apply, if you create new setters elsewhere.
class B < A
A.instance_methods.select{
|name| name.to_s=~/^\w+=$/ #matches setter method names
}.each{|name|
#defines new method in B with identical name
define_method(name){|v| super(v);update();v}
Or you may list specific method names to for which this applies, if you're uncomfortable with relying on automatically detecting relevant method names.
class B < A
[:x=,:y=,:w=,:h=].each{|name|
endEDIT: setters should always return the modified value. If they don't you can quickly run into problems.
Reversing the monkey patching. Such a brilliant, yet simple solution. I wonder why this next logical step didn't occur to me. It is not a callback, but it makes the most sense (when reading the code sometime in the future, it is still obvious)KG_is_back wrote:Define a dummy update method in the parent and include it in each setter. Then you only need to modify the update method in the subclasses
I like this second most. Using a block, it even comes close to callbacks. However, since it is runtime code, it may confuse me, if I go back to the code in the future.KG_is_back wrote:Or you may list specific method names to for which this applies, if you're uncomfortable with relying on automatically detecting relevant method names.Code: Select all
class B < A
What makes you think so? Or do you mean, when using iterating to create the methods? I don't use the return value in the original code example, but access @x directly from the subclass. That's what inheritance is all about (having access to all variables/methods of the superclass). So I hope there isn't a bug hidden somewhere?KG_is_back wrote:EDIT: setters should always return the modified value. If they don't you can quickly run into problems.
https://stackoverflow.com/a/4846249
tulamide wrote:What makes you think so? Or do you mean, when using iterating to create the methods? I don't use the return value in the original code example, but access @x directly from the subclass. That's what inheritance is all about (having access to all variables/methods of the superclass). So I hope there isn't a bug hidden somewhere?
It makes a difference when you stack assignment or use it inside other statements. Here is a simple scenario which would yield incorrect behavior:
#stacked assignment
var=obj.x=5 #you would expect var to receive same value as x. In reality it receives the return value of .x= method, which may be different if you implement .x= method incorrectly.
CODE: SELECT ALL
class B < A
It will confuse the hell out of you. Especially if you are not careful with the order in which ruby components are loaded. The runtime code is only executed once exactly when the component loads. Shenanigans may occur, especially with the first version, when setters of the parent class get defined after this runtime auto-definer for the child class runs. You may easily end up with code working, saving the schematic and be broken or spammed with exceptions when loading the schematic later...
For me the lesson was, that I should never try to let the superclass know of functionality of the subclass.
