clear audio at presetchange
hallo, after this was asked in the general section here is an example of how i avoid clicks, hanging notes or other audiotroubles while presetchange, specially in complex schematics where presetchanges could need up to 1 sec or more.
how it works:
when a programchange happens a trigger gets sent to the clear audio module right before the audio output and the new preset nr is holded on a sample and hold, in the output module the volume is faded to zero and clear audio is triggered which kills all audio activity, after this a trigger is sent to the presetmanagers sample and hold and the presetchange finally happens.
take care that the trigger from the output module is connected correctly with the presetmanager! if you do this wireless everything needs to be on the right level!
clear audio.fsm
(6.85 KiB) Downloaded 1177 times
Re: clear audio at presetchange
Very nice solution!
djbrynte
Post by djbrynte »
very good but are bit advanced :P
it not that complicated, there is just one module to add inside the presetmanager, right after the midi-presetchange, and one right before the audiooutput.
djbrynte
Post by djbrynte »
Can you pls show me an image how to set it up :P you know i have dyslexia mate :D would be so nice of you if u do :)
djbrynte
Post by djbrynte »
i think i solved it 100% thanks man. but there is one little things its still little click. not much but very little on some presets :)
djbrynte
Post by djbrynte »
must have connected it wrong somehow?
I removed DC blockers and its much better just some little clicks but can i get rid of those?
