Bug in time module ??? [solved]
jjs
Post by jjs »
Hi there!
Anyone knows something about the time module not always giving the decimal minutes?
I mean if the time is 17:25 the module gives 17:5 this is not always but it does occur often and on several pc's.
The time is manual asked by push of a trigger
same with FS 3.00 as FS 3.01.
thanks for any help. see pic please.
nb **** what is this sh*tty anouncement??? what does it matter what the size of pic is...***
this--->The image must be at least 0 pixels wide, 0 pixels high and at most 650 pixels wide and 1000 pixels high. The submitted image is 890 pixels wide and 375 pixels high.
resized it, its not ok but you can see
tester
Re: Bug in time module ???
Post by tester »
Time module is fine, your arrangement - not.
Seconds are sent as number (integer), that why you don't get "0", like "01". You need to add some detector, whether number is 1-digt or 2-digts, and depending on result - "0" would be placed before number (keep links order), when sending it to the string.
I guess someone places the example before I finish.
jjs
Post by jjs »
tester wrote:Time module is fine, your arrangement - not.
maybe you're right, i will make a detector if the first digit is of the minutes is 0
edit* ok got it thanks, added a selctor who ads a 0 when the minutes are less then 10
tester
Post by tester »
"most 650 pixels wide" limit vs "890 pixels wide" sieze.
Too wide. ;-)
