ROXY's A.M. L.F.O. Modulator Demonstrator
- rocknrollkat
Hi gang,
If you've been following my posts, you'll recall that I developed a corrected L.F.O. for use in Synthesizers and anywhere else that you need an above "0" referenced audio signal.
I mentioned that the standard +1 to -1 output oscillator would not suffice in synthesizer L.F.O. modulating applications.
To make it perfectly clear, I built this A.M. modulator (V.C.A) demonstrator to point out the problems you will encounter if you use the stock oscillator as an L.F.O.
The results are anywhere from usable but wrong, to totally unusable.
If you've been struggling with L.F.O. applications, this could point the way out of the woods for you.
If you haven't delved into this area yet, my demonstrator will save you a TON of headaches down the road.
Enjoy my latest fsm project and avoid the aspirin !
ROXY
p.s. - If you've been wondering how to build an audio 'chopper', my oscillator in square wave mode is the answer !
ROXY
- ROXY's A. M. Modulator Demonstrator - w. OUTPUT BIAS.fsm
- It's the Christmas season, get those L,F,O,s working correctly !
- (822.79 KiB) Downloaded 1644 times
