CONVERT NUMBER "N" TO THE BASE "A" TO A DECIMAL NUMBER BASE (10) - RUBY
Examples included in the Comment attached to the Schematic.
- Convert Number - n to the Base - a to a Decimal Number Base 10 - Ruby.fsm
- (1.45 KiB) Downloaded 1044 times
Thanks Tiffy !
Hi Tiffy,
Another nice one, keep them coming.
Cheers, BobF.....
Cheers, BobF.....
OBJECT ORIENTED PROGRAMMING (OOP) IN THE RUBY LANGUAGE.
This Anatomy in *.pdf format of how Objects and Methods works, together with the attached DSP Flowstone Ruby Examples 1 through 21, provided me with a better understanding of Object Oriented Programming (OOP) in the Ruby language and I thought that I should share this since maybe it could help other newcomers to OOP as well. This does not cover everything on Objects, Methods, or Classes but it gave me a solid starting point.
I have updated this document so it now contains 20 typed pages and 21 tested Examples that works in Flowstone. I have also corrected some typo's, coloured the headings and added some short notes of value to the original as well.
The document is not yet completed to that point where I would say stop, but I am giving it out in the meantime as it could take some time to get to that point where I say halt...I think I will stop the lorry with Ruby Classes.
Also read tulamide's written documents on the Guru website as mine is only meant for an absolute Flowstone Ruby noob like myself...still learning.
- OBJECT ORIENTED PROGRAMMING (OOP) in RUBY v1.2.rar
- Updated and Corrected version 1.2 - with 21-Ruby Examples that works in Flowstone.
- (368.67 KiB) Downloaded 1043 times
Thanks for the OOP sharing.
It's presented in an easy to follow way [for those of us with no formal].
Thanks
Thanks
This looks SO good Tiffy!
Thank you very much for doing this for us.
Tiffy, in your pdf you encourage other Rubyists to improve or add. So I do.
While you are right in your descriptions, the resulting code is considered bad writing. On-the-fly creation should be an exception for certain specific cases. In all other cases there's a better style. Objects are classes. You can use them as synonyms. In fact, 'Object' in Ruby is the root class, where all other classes derive from.
I made a three part series, called "Ruby Stripped" a few years ago on Flowstone Guru. It introduces the terms object, class, method, etc. It also provides graphics of applications within Flowstone, and fsm-files. Maybe it helps getting a better view over the concept of class creation/management?
Ruby Stripped, Part 1: Introduction to classes
Ruby Stripped, Part 2: Objects
Ruby Stripped, Part 3: Arrays
tulamide, thank you for all this info on Ruby. Much appreciated.
You're welcome
