you can exchange the ticker with the old version which should be in your toolbox..
ah ... ok.
I replaced the 'ticker' module, and all is working.
I fed the 'state' Boolean into the stock 'ticker' module and everything starts and re-sets nicely.
Also changed the LED to GREEN when active.
RJHollins wrote:ah ... ok.
Glad your (my) problem is solved mate. However, I would still like to have a look at the old Ruby Ticker code just to see where the difference is between the old & the new. Would it be inconvenient to ask you to post the old Ruby ticker here, as I don't have a copy of v3.0.4 ?
Thanks for the help from Tulamide & Nubeat7.
Absolutely !
Here is the Graphics CountDown schematic you posted, with my changes.
RJHollins wrote:Absolutely !
Thank you, appreciate.
ONE DROPLIST ONLY (RUBY) + 2 x SELECTORS WITH DROP LISTS (RUBY):
Please note that the two Ruby Selectors are not exactly the same as the one has a static label and the other a dynamic label which corresponds to the item selected. The Ruby Drop List Only has intentionally no background and can be used as a hidden Drop list.
I don't know if anyone noticed that the previous Ruby Selectors & Ruby Drop List I uploaded to the DSP Forum some time ago, although they all retained their settings the setting displayed on their Drop lists reverted to 0 after a shutdown and a restart of the schematic.
So, that bug were fixed in this upload and I think the schematics is also a bit neater.
- Droplist + 2 Selectors (Ruby).fsm
- (6.11 KiB) Downloaded 1219 times
there are a few things to say about..
1. to place a redraw inside the draw methode forces an endless redraw loop
2. if you redraw inside ruby, no extra redraw primitives are needed
3. "d = @inside ? 20:0" - no variable of this line is used..
4. "output 2,v.height" - there is no output 2
5. it is a useless overload, to load all pc fonts on each start of the app, you can purgeable this
6. the init methode - @index = @index - better check if nil or?
7. preset management would be helpful too
i also wouldn't initialise "b" 2 times because it is confusing to have one variable which does 2 different things in one methode..
ps: you don't need to delete everything again, i stopped commenting your stuff, this is just an exception, because i'm bored, i promise
RUBY RANDOM NUMBER GENERATOR (FROM A RANGE).
I am not sure if this is the best Ruby method I used for the Random Number Generator, however I tried to keep the Ruby Code as simple and as short as possible.
So, please first test it before using it in any application.
- RandomNumberGenerator (Ruby).fsm
- (4.97 KiB) Downloaded 1152 times
Hey tiffy that's great and gone into my toolbox!
RUBY RANGES:
Ruby supports ranges and allows us to use ranges in a variety of ways:
1) Ranges as Sequences
2) Ranges as Conditions
3) Ranges as Intervals
Just in case someone wonders what the "range.to_a" method (convert a range to a list) does in the Random Number Generator I posted previously, here is a link that explains it quite well:
https://www.tutorialspoint.com/ruby/ruby_ranges.htm
