Robot Mag. Alien Arm
A wide range of example files that you can load up in FlowStone
admin
Site Admin
Post by admin »
Here is the source code used for the Robot magazine review of FlowStone.
This program controls a LynxMotion Robot arm with a web cam attached and a laser! The web cam detects movement and hunts down RED targets, before firing the laser. The laser is fired using a Phidgets 0/0/4 relay board.
This program also contains the Inverse Kinematics (IK) required to move the arm at any desired position.
Have Fun!
Alien Arm V1-07.fsm
(461.11 KiB) Downloaded 4766 times
