Lissajou Art
Re: Lissajou Art
Hi lalalandsynth
At the moment I'm not inclined to re-work this old project but I've attached modules I use to save any string or float values. You just place the module in series with the parameter you wish to save in the preset and, importantly, give each parameter a unique name (can be anything).
You can effectively rotate the image clockwise by 90 degrees using the Swap L/R knob.
You can set transparency using the alpha channel and I've attached some tools I've collected. They either generate a complete colour or add transparency to a colour prim (wired in series).
The final "output" view of PHI's excellent lissajou display can be saved as a bitmap etc using the module I uploaded elsewhere.
Thanks for trying this module BTW. I had a lot of fun and interest at the time.
- Colour tools.fsm
- (117 KiB) Downloaded 1203 times
- Preset float and string saving.fsm
- (2.11 KiB) Downloaded 1258 times
- lalalandsynth
Re: Lissajou Art
HI Spogg , thanks a lot , love this thing !
Re: Lissajou Art
I had the vision of making moving text etc but it would have meant some severe programming, probably in Ruby, but I'm not up to that at the moment.
Maybe one day...
Thanks for the thanks!
Maybe one day...
Re: Lissajou Art
Hello Gang!.... I look this projects... This sooo Coool!!!
Spogg, Devilish V2.... thanks a lot!!!.... This fantastic look!!!
- 3DBP.png (126.52 KiB) Viewed 26174 times
Re: Lissajou Art
I needed a sweeping pan your concept looked like the prefect build for it so I made a sweeping pan out of it
- Bobs Lissajou Art_tweak1.fsm
- (210.64 KiB) Downloaded 1135 times
Re: Lissajou Art
Hello bar_cobb,
Thanks for sharing, great job. I just put it in my toolbox. Keep up the great work and hope to see a lot more from you in the coming months.
Cheers, BobF.....
Cheers, BobF.....
Re: Lissajou Art
no problem just getting the hang of flowstone I just know the basics don't know what your plan was for this but I think what I have made would be a good wave shaper.
Re: Lissajou Art
Good idea, why don't you see if you can develop it. Good luck!
Later then, BobF.....
