Sorting File paths
Sorting File paths
Hey guys, i've been scratching my head over this one. Lets say I have an array containing some file paths:
Folder/1.txt
Folder/23.txt
Folder/6.txt
Folder/Piano.txt
Folder/Wave01.txt
Folder/Wave02.txt
Zebra/1.txt
Zebra/76.txt
Zebra/9.txt
Now when ruby gets these paths it looks different from windows. Ruby thinks 23 comes after 1 because it starts with a 2, but they should be numerically higher, like this:
Folder/1.txt
Folder/6.txt
Folder/23.txt
Folder/Piano.txt
Folder/Wave01.txt
Folder/Wave02.txt
Zebra/1.txt
Zebra/9.txt
Zebra/76.txt
Is there a way to sory them by using the .sort_by function or something else?
Thank you!
Folder/1.txt
Folder/23.txt
Folder/6.txt
Folder/Piano.txt
Folder/Wave01.txt
Folder/Wave02.txt
Zebra/1.txt
Zebra/76.txt
Zebra/9.txt
Folder/1.txt
Folder/6.txt
Folder/23.txt
Folder/Piano.txt
Folder/Wave01.txt
Folder/Wave02.txt
Zebra/1.txt
Zebra/9.txt
Zebra/76.txt
Thank you!
Re: Sorting File paths
What you are looking for is called "natural sort". I found a conversation on StackOverflow here, and made a quick fsm. It isn't bullet-proof! If any of your strings start with a number it will result in an error. However, if your strings are like in your example, it works.
To make this work in your project, you have to make sure that this code is initialized before you access it:
class String
def naturalized
scan(/[^\d]+|[\d]+/).collect { |w| w.match(/\d+/) ? w.to_i : w }
end- Attachments
- natural_sort_2.fsm
- (434 Bytes) Downloaded 864 times
Ah thank you, just what I was looking for!
