Synthmaker -> Flowstone Migration
rlr
Post by rlr »
I did an A/B comparison of an osm file exported as a VSTi dll with the osm converted with FS and exported to VSTi. Everything is working, the one notable difference is the dll size, the FS export has ~1 additional MB than the SM export.
The only thing that bugs me is that Hermann Seibs VST host reports the FS export as "exports VST SDK <= 2.3 main function". Wasn't FS supposed to generate VST 2.4 compatible plugins? or did I overlook something?
jjs
Re: Synthmaker -> Flowstone Migration
Post by jjs »
somewhere on the SM forum this is allready been spoken about and has to do with some setting in flowestone, search on that forum and you also see the answer of Malc
The additional file size probably comes from Ruby - for plugins with Ruby, the interpreter and definitions of the FlowStone Ruby objects and methods will need to be 'wrapped' into the .dll.
infuzion
Post by infuzion »
trogluddite wrote:The additional file size probably comes from Ruby - for plugins with Ruby, the interpreter and definitions of the FlowStone Ruby objects and methods will need to be 'wrapped' into the .dll.
This, plus all the new primitives. Remember that old primitives never get deleted, so that old Mono Multiply is still in the .dll.
I am surprised it is only 1Mb additional for all that.
rlr
Post by rlr »
The additional filesize is no problem. Its good to have the ruby runtime integrated into the plugin DLL.
But is it really VST 2.4?
jjs
Post by jjs »
Read this about the vst 2.4, it is there and working as CoreStyler also confirmed.
http://synthmaker.co.uk/forum/viewtopic ... =90#p89888
rlr
Post by rlr »
I was confused that VSThost reported an exported plugin as a VST 2.3 plugin. But after a more thorough look it indeed seems to be VST 2.4 compliant.
digitalwhitebyte
Post by digitalwhitebyte »
rlr wrote:I was confused that VSThost reported an exported plugin as a VST 2.3 plugin. But after a more thorough look it indeed seems to be VST 2.4 compliant.
you can inspect with this utility for better info
vst_scanner
