Oneshot Sequencer
BobF
Oneshot Sequencer
Post by BobF »
BobsOneShotSequencer.fsm
(580.02 KiB) Downloaded 1191 times
Hello gang,
Ok, this is a short of weird sequencer I came up with. It's five stages of oneshots (mono-stables) wired in series with a variable clock (osc) feeding the chain. The times can be set for each oneshot in milliseconds, there is a tap at each output with it's own volume control then summed and fed to three oscillators. Also the oneshots can be modulated via a lfo, there's a scope to view the waveform, and last a slew limiter before the three oscillators. Note there is a selector to select either one, two, or all three of the oscillators. This sequencer even though different from many others around can produce many , many cool sequences. I have even added an external clock and mod inputs and a external audio out and the summed oneshot output for more fun. It is presented as a packed module, but I would hope many of you take it apart and experiment a lot. Much, much more can be done here. The oneshots could of course be extended (or shortened), made parallel or series parallel, put under vca control, each oneshot could be modulated, ring modulated, and on and on.
So have fun, and please, please, experiment and if you do as always please share here at the forum.
Later then, BobF.....
Re: Oneshot Sequencer
Wow Bob!
Wild and crazy as ever and very creative too!
I think everyone here who reads my stuff will know that I do like to interfere so here's a few points, having played with it a bit:
-The "Volume" label is a bit misleading: these knobs set the peak frequency of the sweep.
-it would be nice to be able to bypass the DC filter so you could choose to sweep or not.
-It might be nice not to just have the DC filter but to experiment with various transfer functions like maybe a state variable filter or rate limiter; this could provide a large range of sweep behaviours.
-The preset parameter names are not unique throughout the schematic which means preset save and load behaviour won't be predictable
-The name label is cut off top and bottom. This may have been intentional!
All these points are offered as help and ideas, not crticism.
Thanks as always for sharing.
BobF
Post by BobF »
Hi Spogg,
You are absolutely correct, my bad. It was 2 in the morning , my free time, and I just hit enter and went to bed. Some very good suggestions and I will fix the presets once again. Never feel bad on saying anything about my posts, at least you say something, and it is always very much apprexisted.
BobF
Post by BobF »
(1.31 MiB) Downloaded 1136 times
Hello gang,
Ok here is a update on my "One-shot Sequencer", I added a few things as Spogg suggested and I do believe it is much better. The big thing is I added a slew limiter for each of the five one-shots. This does give a lot more sound choices. Some that are really cool. For more information just read the above first posting and just play around with it a lot.
Have fun, and if you come up with any cool mods or presets PLEASE post.
Much improved and more versatile! Well done :D
The preset parameter names still need attention so users can program and interface correctly.
I reckon the timing will be more predicatble as a VST and/or exe so when you've got the preset parameter naming sorted I will test and upload the exports, assuming all is well.
I was able to make some interesting sequences with it as it is.
