Switch with interaction help
hey people,
i am looking to build pretty simple midi control sending vst plugins using flowstone for some external synths and got stuck on one small bit. it seems i can not find a switch with interaction and can't seem to implement it right into an existing switch.
the interaction between the hardware synth and the vsti need to work both ways, and currently the switch is the only component that is only not responding to changes that come via the hw synth.
i am using a knob schematic found on the forum and it is working great, any help in getting the switch to operate in the same method would be great. i attached a schematic with the knob that i'm using as well as the switch that i would like to try to get interaction to work on.
appreciated lots!
appreciated lots!
- switch_like_knob_interaction.fsm
- (123.37 KiB) Downloaded 835 times
Scope DSP Plugins and more
http://www.oceanswift.net/
Re: Switch with interaction help
nevermind, solved! i'll post eventually some nice midi knobs
