Approximate numbers Help
Wassaka
Post by Wassaka »
First, Probably is a very very easy thing to do but i am very newbie... Well I am trying to approximate a decimal number to a whole number. Thanks and sorry my ignorancy :roll: :|
Re: Approximate numbers Help
use the ROUND primitive. You can set the number of decimal places.
Nowhk
Post by Nowhk »
RJHollins wrote:use the ROUND primitive. You can set the number of decimal places.
Is it somethings added on 3.0.9? I can't see any ROUND primitive in my toolbox :shock:
I always do this passing the value via Ruby :?
no ... its been there forever.
check/search toolbox for things like 'formatting'.
tomorrow I'll look up what I have.
Nowhk
Post by Nowhk »
RJHollins wrote:no ... its been there forever.
I know that, but it's for string.
nix
Post by nix »
Here is stream and green->
integers.fsm
(606 Bytes) Downloaded 880 times
Nowhk
Post by Nowhk »
nix wrote:Here is stream and green->
integers.fsm
Yes. But I meant: what if you have a Float prim with value 2.234523 and you want to "round" to 2 digit (i.e. 2.23)?
Such as round in Ruby.
nix
Post by nix »
edit- Nowhk mate, this wasn't a reply to you, just showing it if it doesn't open in current FS.
I'm sure I know how to format, just a sec
nix
Post by nix »
format.fsm
(381 Bytes) Downloaded 948 times
Formatting command was found by Trogluddite,
hope helps, but maybe not what you want
Nowhk
Post by Nowhk »
nix wrote:
format.fsm
Not sure how fast is passing between float-string-float. Anyway, that's won't "round" really to the last digit, just "cut" the string.
