Ruby Knob fully customisable
here is a fully customisable rubyknob.
latest version:
ruby_knob_3_001.fsm
(3.25 KiB) Downloaded 1151 times
TheAudiophileDutchman
Re: Ruby Knob fully customisable
Great stuff, very smooth :!:
T A D - since 2005
philton
Post by philton »
thx for sharing NuBeat, maybe i understand that Ruby stuff a little bit more when i have a look at your work and how
you made this knob...
philton wrote:thx for sharing NuBeat, maybe i understand that Ruby stuff a little bit more when i have a look at your work and how
basically i tried the things which you can find in the FS userguide, all the grafic stuff is written down there with examples...
unkargherth
Post by unkargherth »
A ittle update. Made it still more configurable ( Sky is the limit ! )
Changelog inside
rubyknob-v1.1.fsm
(6.62 KiB) Downloaded 1785 times
Free your memory, .. with a free(). Like a pointer
Cast a pointer into an integer and it becomes the integer...
Cast a pointer into a struct and it becomes the struct...
A pointer can overflow... or can crash...
Be a pointer my friend
Great work, guys - this is just what FS3 needs now, a big selection of cool user modules so that folks get a good choice of different 'looks' etc., and stuff to learn from.
And I always preferred the knobs with a sweep arc - I find them so much easier to read at a distance.
unkargherth wrote:A ittle update. Made it still more configurable ( Sky is the limit ! )
Changelog inside
rubyknob-v1.1.fsm
great update unkargherth, its so much cleaner inside now, also the properties are much better readable with more things to do, thanks for this!
matti
Post by matti »
How to hide and hold the mouse pointer when turning the knob?
unkargherth
I understand about hide.. but can you explain in detail what is the "hide and hold" behaviour ?
Hold is where, when the cursor 'unhides' it is still in the same place where clicked - so changing the control does not move the pointer position, and it is easy to find when you let go of the button.
