Ruby problem?
adic
Ruby problem?
Post by adic »
Hello,
I made an example of Ruby animation on FS 3.06, which does not work for some reason on the latest version 3.08.1 (trial). Have DSProbotics perhaps changed the specification of Ruby's draw method?
So long
circle_lfo.fsm
this schematic works well on FS3.06 but does not work on FS3.08.1
(14.9 KiB) Downloaded 986 times
Re: Ruby problem?
Post by KG_is_back »
The problem is, variable @x now by default references the current Thread. Unfortunately you cannot use it. Just change it to some different name and everything should be OK
adic
Re: Ruby problem?
Post by adic »
Hello, KG
I've replaced the variable names (@x -> @x1) as you told and the schematic is working well on the latest version 3.08.1.
thank you.
circle_lfo_v2.fsm
corrected version
(15.36 KiB) Downloaded 975 times
