Ruby.Array.Problem.(Solved)
Parki
Post by Parki »
Look to the file.
Ruby.Array.Problem..fsm
(1.22 KiB) Downloaded 834 times
I hope my english was understeandable.
Skype id - parkidesu
Re: Ruby.Array.Problem.
Parki
Post by Parki »
I won't be rude but...
Any work code which add an array to array?
you can find all you can do with arrays in the link above
http://ruby-doc.org/core-2.2.0/Array.html#method-i-2B
to add an array to another just "add" them,
so if you want to add arrayB to arrayA:
arrayA = arrayA + arrayB
or shorter
arrayA += arrayB
Nubeat7 wrote:http://ruby-doc.org/core-2.2.0/Array.html#method-i-2B
I propose to link to core 1.9.3 instead, because that's what Flowstone uses. It has no influence on this particular question, since nothing has changed for arrays. But this might not always be the case. :)
Parki
Post by Parki »
I almost pray for it would be last.
5.fsm
(1.19 KiB) Downloaded 815 times
TheOm
Post by TheOm »
Take a look at this:
5.fsm
(1.3 KiB) Downloaded 828 times
Parki
Post by Parki »
Thank you guys for your help me with my idiotic problems with syntax.
