Loudness Meter-Comparison Tool - EBU R128
Youlean
Post by Youlean »
This should compare perceived loudness between A and B. I have compared it to the Nugen VisLM-H and it is pretty accurate. It could be useful when you need to measure loudness off distortion. For example, you can connect clean sine wave on A, and limited sine wave on B (just make sure that peak out is the same as A), and to measure how audible is distortion, or you can compare 2 different algorithms for limiter (that's what I need it for), and to see which one gives you less distortions.
Loudness Comparison Tool.fsm
(49.69 KiB) Downloaded 1616 times
Exo
Re: Loudness Comparison Tool
Post by Exo »
Nice, thanks!
Hi Youlean,
I've not check the schematic as yet ... but wondered ...
Are you using the EBU R128 as the reference ??
Youlean
Post by Youlean »
Sorry for late response... Previous version was my attempt of measuring loudness, and it was not working properly because K weighting was not applied. New version does use EBU R128. I have added also a separate loudness measurement tool.
Loudness Meter-Comparison Tool.fsm
(16.34 KiB) Downloaded 1600 times
Re: Loudness Meter-Comparison Tool
hmm .. will check this out ! Look forward to this :)
Youlean
Re: Loudness Meter-Comparison Tool - EBU R128
Post by Youlean »
Well, I have compared it with Nugen VisLM-H using sine waves with multiple frequencies, and margin of error was 0.2LUFS max. This is probably because K Weighting filter is not 100% same as in Nugen VisLM-H. This should be acceptable margin of error (or at least that's what paper for EBU R128 algorithm says).
Test it and post here results please.. :)
Just now getting to try this out.
Not sure I'm doing it right, I hooked up a Wave Player to the 2 modules ... hit play, see nothing in the display :?
Youlean
Post by Youlean »
Try this... You must select ASIO output...
Loudness Meter Test.fsm
(15.98 KiB) Downloaded 1559 times
hmm ... I can hear the OSC [when hooked up]. The Vol knob does its thing.
Still nothing in the display :(
I'm running FS 3.0.4 [hope that's not the issue].
Youlean
Post by Youlean »
Ok. Can you do a screenshot?
