Printing in a kind'o'way
JB_AU
Post by JB_AU »
If i have an image file i can print this from within fs with;
rundll32 C:\WINDOWS\system32\shimgvw.dll,ImageView_PrintTo "c:\myfile.bmp" "Brother DCP-165C Printer"
The thing i am looking for is capturing a part of the fs window, saving it and then pipe of to shimgvw.dll
This is were i am stuck, as the final gui doesn't have separate wHandle's , so my thinking of current is to take the values of a module and launch in a separate window where i can pre format the data & then print.
All ideas appreciated
Albert Einstein
Tronic
Re: Printing in a kind'o'way
Post by Tronic »
My idea is to grab the screen with simulate the key press of keyboard Print, so save the clipboard data to file, open it in FS, manipulate and send it to Printer.
JB_AU
Post by JB_AU »
Problem with send keys, how do you interpret when a user uses the keyboard & how do you edit the image only to include the area you want.
Albert Einstein
Tronic
Post by Tronic »
using only commnd line thing, or WinAPI you can not do what you want,
with the WinAPI but you may do so:
check the focus of the current window
simulate a keypress button Print
save the image that is now on the clipboard
to have a control over the size and position you should opt for a solution in DLL
JB_AU
Post by JB_AU »
I've already started with gdi , but thanks tho!
Albert Einstein
JB_AU
Post by JB_AU »
With win32api i am trying to put these pieces together slooooowly
Win32API.new("user32", "GetWindowDC", "L", "L")
Win32API.new("gdi32", "CreateCompatibleDC", "L", "L")
Win32API.new("gdi32","CreateCompatibleBitmap", ["L", "I", "I"], "L")
Win32API.new("gdi32", "SelectObject", ["L", "L"], "L")
Win32API.new("gdi32", "BitBlt", "L", "I", "I", "I", "I", "L", "I", "I", "L", "B")
#Pipe from mem to printer
#ReleaseDC
#DeleteDC
#DeleteObject
Albert Einstein
JB_AU wrote:With win32api i am trying to put these pieces together slooooowly
#ReleaseDC
#DeleteDC
#DeleteObject
One question: Where do you grab the constants' values from? I was interested in doing some win32api accessing, too, when trying to provide a solution for menus and listboxes, but the neccesssary constants' values are not on msdn, just their names. Are you using the header files? Where did you download them? Questions over questions... :mrgreen:
JB_AU
Post by JB_AU »
https://www.google.co.jp/?hl=en&gws_rd=ssl
Which gives more information on ruby & win32api than "EnGoogle" itself :x
Albert Einstein
JB_AU
Post by JB_AU »
Strolling for more information i came across these goodies
require 'Win32API'
module GDIP
  CLSID_BMP     = '557CF400-1A04-11D3-9A73-0000F81EF32E'
  CLSID_JPEG    = '557CF401-1A04-11D3-9A73-0000F81EF32E'
  CLSID_GIF     = '557CF402-1A04-11D3-9A73-0000F81EF32E'
  CLSID_TIFF    = '557CF405-1A04-11D3-9A73-0000F81EF32E'
  CLSID_PNG     = '557CF406-1A04-11D3-9A73-0000F81EF32E'
  CLSID_QUALITY = '1D5BE4B5-FA4A-452D-9CDD-5DB35105E7EB'
  CP_ACP   = 0x0000
  CP_UTF8  = 0xFDE9
  MultiByteToWideChar       = Win32API.new('kernel32', 'MultiByteToWideChar', 'iipipi', 'i')
  FindWindow          = Win32API.new('user32', 'FindWindow', 'pp', 'l')
  GetDC          = Win32API.new('user32', 'GetDC', 'i', 'i')
  ReleaseDC          = Win32API.new('user32', 'ReleaseDC', 'ii', 'i')
  BitBlt          = Win32API.new('gdi32', 'BitBlt', 'iiiiiiiii', 'i')
  CreateCompatibleDC       = Win32API.new('gdi32', 'CreateCompatibleDC', 'i', 'i')
  CreateCompatibleBitmap    = Win32API.new('gdi32', 'CreateCompatibleBitmap', 'iii', 'i')
  SelectObject          = Win32API.new('gdi32', 'SelectObject', 'ii', 'i')
  DeleteDC          = Win32API.new('gdi32', 'DeleteDC', 'i', 'i')
  DeleteObject          = Win32API.new('gdi32', 'DeleteObject', 'i', 'i')
  GdiplusStartup       = Win32API.new('gdiplus', 'GdiplusStartup', 'ppi', 'i')
  GdipCreateBitmapFromScan0    = Win32API.new('gdiplus', 'GdipCreateBitmapFromScan0', 'iiiipp', 'i')
  GdipCreateBitmapFromHBITMAP    = Win32API.new('gdiplus', 'GdipCreateBitmapFromHBITMAP', 'iip', 'i')
  GdipBitmapConvertFormat    = Win32API.new('gdiplus', 'GdipBitmapConvertFormat', 'piiipi', 'i') rescue nil
  GdipSaveImageToFile       = Win32API.new('gdiplus', 'GdipSaveImageToFile', 'pppp', 'i')
  GdipDisposeImage       = Win32API.new('gdiplus', 'GdipDisposeImage', 'p', 'i')
  GdiplusShutdown       = Win32API.new('gdiplus', 'GdiplusShutdown', 'p', 'v')
  UuidFromString       = Win32API.new('rpcrt4', 'UuidFromString', 'pp', 'i')
  GdipBitmapLockBits       = Win32API.new('gdiplus', 'GdipBitmapLockBits', 'ppiip', 'i')
  GdipBitmapUnlockBits       = Win32API.new('gdiplus', 'GdipBitmapUnlockBits', 'pp', 'i')
  RtlMoveMemory       = Win32API.new('kernel32', 'RtlMoveMemory', 'ppi', 'v')
  PF_RGB  = 0x00021808
  PF_ARGB = 0x0026200A
  WINDOW_TITLE  = load_data("Data/System.rvdata2").window_title.encode('SHIFT_JIS')
  WINDOW_HANDLE = FindWindow.call("RGSS Player", WINDOW_TITLE)
module_function
  def MultiByteToWideChar(str)
    buffer = [""].pack('Z256')
    MultiByteToWideChar.call(CP_UTF8, 0, str, -1, buffer, buffer.size)
    return buffer
  def GetDC(hwnd)
    return GetDC.call(WINDOW_HANDLE)
  def ReleaseDC(hwnd, hdc)
    ReleaseDC.call(hwnd, hdc)
  def CopyDC(dest, src, width, height)
    BitBlt.call(dest, 0, 0, width, height, src, 0, 0, 0xCC0020)
  def CreateCompatibleDC(hdc)
    return CreateCompatibleDC.call(hdc)
  def CreateCompatibleBitmap(hdc, width, height)
    return CreateCompatibleBitmap.call(hdc, width, height)
  def SelectObject(hdc, obj)
    return SelectObject.call(hdc, obj) != 0
  def DeleteDC(hdc)
    DeleteObject.call(hdc)
  def DeleteObject(obj)
    DeleteObject.call(obj)
  def GdiplusStartup(token)
    ret = GdiplusStartup.call(token, [1, 0, 0, 0].pack("i4"), 0) == 0
    unless ret
      msgbox "GDI+ failed in the initialization."
    return ret
  def GdipCreateImageFromBitmap(bitmap)
    gpbmp = [0].pack("i")
    if GdipCreateBitmapFromScan0.call(
      bitmap.width, bitmap.height, 0, PF_ARGB, 0, gpbmp) == 0
      image = gpbmp.unpack("i")[0]
      r = [0, 0, bitmap.width, bitmap.height].pack("i4")
      bd = [0, 0, 0, 0, 0, 0].pack("i6")
      GdipBitmapLockBits.call(image, r, 3, PF_ARGB, bd)
      GdipBitmapUnlockBits.call(image, bd)
      bd = bd.unpack("i*")
      data = Array.new(bitmap.width * bitmap.height * 4, 0).pack("C*")
      RtlMoveMemory.call(data, bitmap.data, data.size)
      data = data.unpack("C*")
      data = Array.new(bitmap.height) do |i|
        data[data.size - bitmap.width * 4 * (i + 1), bitmap.width * 4]
      end.flatten!.pack("C*")
      RtlMoveMemory.call(bd[4], data, bitmap.width * bitmap.height * 4)
      return image
    else
      return nil
  def GdipCreateImageFromHBITMAP(hbm)
    if GdipCreateBitmapFromHBITMAP.call(hbm, 0, gpbmp) == 0
      return gpbmp.unpack("i")[0]
    else
      return nil
  def GdipSaveImageToFile(image, filename, clsid)
    ret = GdipSaveImageToFile.call(image, filename, UuidFromString(clsid), 0)
    msgbox "failed to save." if ret != 0
  def GdipImageConvertPixelFormat(image, pixel_format)
    return unless GdipBitmapConvertFormat
    GdipBitmapConvertFormat.call(image, pixel_format, 0, 0, 0, 0)
  def GdipDisposeImage(image)
    GdipDisposeImage.call(image)
  def GdiplusShutdown(token)
    GdiplusShutdown.call(token)
  def UuidFromString(clsid)
    uuid = [0].pack("i")
    UuidFromString.call(clsid, uuid)
    return uuid
class Bitmap
  RtlMoveMemory_pi = Win32API.new('kernel32', 'RtlMoveMemory', 'pii', 'i')
  RtlMoveMemory_ip = Win32API.new('kernel32', 'RtlMoveMemory', 'ipi', 'i')
  def info
    dib = [40, self.width, self.height, 1, 32, 0, 0, 0, 0, 0, 0].pack("i3s2i6")
    return [dib].pack("P").unpack("i")[0]
  def data
    buffer = [0].pack('L')
    RtlMoveMemory_pi.call(buffer, object_id * 2 + 16, 4)
    RtlMoveMemory_pi.call(buffer, buffer.unpack("L")[0] + 8, 4)
    RtlMoveMemory_pi.call(buffer, buffer.unpack("L")[0] + 16, 4)
    return buffer.unpack("L")[0]
  def save(fn, type, back = nil)
    bitmap = Bitmap.new(self.width, self.height)
    case back
    when Color;       bitmap.fill_rect(self.rect, back)
    when Array;       bitmap.fill_rect(self.rect, Color.new(*back))
    when /^white$/i;  bitmap.fill_rect(self.rect, Color.new(255, 255, 255))
    bitmap.blt(0, 0, self, self.rect)
    case type
    when /^BMP$/i;    clsid, ext = GDIP::CLSID_BMP,   ".bmp"
    when /^PNG$/i;    clsid, ext = GDIP::CLSID_PNG,   ".png"
    when /^JPE?G$/i;  clsid, ext = GDIP::CLSID_JPEG,  ".jpg"
    when /^GIF$/i;    clsid, ext = GDIP::CLSID_GIF,   ".gif"
    else;             raise ""
    fn += ext if File.extname(fn).empty?
    filename = GDIP::MultiByteToWideChar(fn)
    token = [0].pack("i")
    if GDIP::GdiplusStartup(token)
      image = GDIP::GdipCreateImageFromBitmap(bitmap)
      if image
        GDIP::GdipSaveImageToFile(image, filename, clsid)
        GDIP::GdipDisposeImage(image)
      GDIP::GdiplusShutdown(token)
    bitmap.dispose
  def save_png(filename, alpha = false)
    save(filename, :PNG, alpha ? nil : :white)
module Graphics
  def self.save_screen(fn, type)
    case type
    else;             raise ""
    wnddc = GDIP::GetDC(GDIP::WINDOW_HANDLE)
    memdc = GDIP::CreateCompatibleDC(wnddc)
    hbm = GDIP::CreateCompatibleBitmap(wnddc, Graphics.width, Graphics.height)
    if GDIP::SelectObject(memdc, hbm)
      GDIP::CopyDC(memdc, wnddc, Graphics.width, Graphics.height)
        image = GDIP::GdipCreateImageFromHBITMAP(hbm)
        GDIP::GdipImageConvertPixelFormat(image, GDIP::PF_ARGB)
        if image
    GDIP::ReleaseDC(GDIP::WINDOW_HANDLE, wnddc)
    GDIP::DeleteDC(memdc)
    GDIP::DeleteObject(hbm)
And this i like too;
require 'Win32API'
OpenPrinter     = Win32API.new('winspool.drv','OpenPrinter', ['P', 'P', 'P'], 'L')
StartDocPrinter = Win32API.new('winspool.drv','StartDocPrinter', ['L', 'L', 'P'], 'L')
EndDocPrinter   = Win32API.new('winspool.drv','EndDocPrinter', ['L'], 'L')
WritePrinter    = Win32API.new('winspool.drv','WritePrinter', ['L', 'P', 'L', 'P'], 'L')
ClosePrinter    = Win32API.new('winspool.drv','ClosePrinter', ['L'], 'L')
GetLastError    = Win32API.new('kernel32','GetLastError', [], 'L')
def open_printer(nm, dev=nil)
    hdl = [0].pack("I")
    r = OpenPrinter.call(nm, hdl, nil)
    hdl = hdl.unpack("I")[0]
    [r, hdl]
def start_doc_printer(hdl)
    StartDocPrinter.call(hdl, 1, "\0"*4*3)
def write_printer(hdl, data)
    sz = [0].pack("I")
    rslt = WritePrinter.call(hdl, data, data.size, sz)
    [rslt, sz.unpack("I")[0]]
def end_doc_printer(hdl) EndDocPrinter.call(hdl) end
def close_printer(hdl) ClosePrinter.call(hdl) end
if __FILE__ == $0
    if ARGV.size <= 1
        print "Usage: #{$0} spoolfile printer\n"
        exit
    prn = ARGV[1].dup
    rslt, hdl = open_printer(prn)
    print "OpenPrinter(#{prn}) --> #{rslt}, hdl:#{hdl}\n"
    rslt = start_doc_printer(hdl)
    print "startDocPrinter --> jobnum: #{rslt}\n"
    spldata = ""
    File.open(ARGV[0], "rb") {|fp| spldata = fp.read}
    rslt, sz = write_printer(hdl, spldata)
    print "WritePrinter    --> #{rslt}, size:#{sz}, err:#{GetLastError.call}\n"
    rslt = end_doc_printer(hdl)
    print "endDocPrinter   --> #{rslt}\n"
    rslt = close_printer(hdl)
    print "closePrinter    --> #{rslt}\n"
I'm salivating :shock: :o
Albert Einstein
Exo
Post by Exo »
JB_AU wrote:Strolling for more information i came across these goodies
require 'Win32API'
module GDIP
  CP_ACP   = 0x0000
  CP_UTF8  = 0xFDE9
  PF_RGB  = 0x00021808
module_function
    return buffer
  def GetDC(hwnd)
  def DeleteDC(hdc)
    unless ret
    return ret
      return image
    else
      return nil
    else
      return nil
    return uuid
class Bitmap
  def info
  def data
    case back
    case type
    else;             raise ""
      if image
    bitmap.dispose
module Graphics
    case type
    else;             raise ""
        if image
require 'Win32API'
    hdl = [0].pack("I")
    [r, hdl]
    sz = [0].pack("I")
if __FILE__ == $0
    if ARGV.size <= 1
        exit
    prn = ARGV[1].dup
    spldata = ""
Very cool JB_AU :)
I might have to look into this more myself ;)
