Log Float Array
Youlean
Log Float Array
Post by Youlean »
Is there any way to log Float Array?
MyCo
Re: Log Float Array
Post by MyCo »
log.fsm
(514 Bytes) Downloaded 868 times
Youlean
Re: Log Float Array
Post by Youlean »
Thanks, but I was thinking of how to log array, so that we don't need to turn on log on the graph line primitive.
tester
Re: Log Float Array
Post by tester »
If you were thinking on using decibes, just use the decibel prim, without multiplicator after. This converts values from linear to log.
Re: Log Float Array
Post by KG_is_back »
Youlean wrote:Thanks, but I was thinking of how to log array, so that we don't need to turn on log on the graph line primitive.
So basically you want to log the x part (the indexes of values) - not the y part (the values them selfs). This is very tricky to do - simplest way is to use some kind of interpolation and create [x,y] point array where x value are "loged" and y values are created from that.
