ifthenelse for arrays in ruby?
TheOm
Re: ifthenelse for arrays in ruby?
Post by TheOm »
What do you mean by ranges? It works for strings too:
Schematic1_new.fsm
(594 Bytes) Downloaded 972 times
tester
Post by tester »
Thanks!
By ranges - let say that I'm not a good rubyist. :mrgreen:
tester
Post by tester »
Small problem. If I change the input type from "string array" into "int array" - ruby module no longer works (empty ouptuts). Can this be fixed, so that there is no need to use text primitive between nodes?
Tronic
Post by Tronic »
you mean this?
battle_tester_vs_ruby.fsm
(602 Bytes) Downloaded 1005 times
tester
Post by tester »
Yes, thanks.
Tronic wrote:you mean this?
haven't checked the fsm ... but the file title gave a chuckle
:lol:
tester
Post by tester »
It took me two minutes to realize the difference. Quotation marks. :-)
I'm in the middle of heavy brainstorming. Creating a cookbook according to TCM - yet another unusual application of FS. (yep, I hear these voices - definately with x64 cooking would be 2x faster :mrgreen:).
tester
Post by tester »
I have one more thing.
I'd like to convert one bigger array according to rules stored in two smaller arrays. Like this.
input array:
el1
el2
el3
el1
el3
contitions arrays ("=" separated to make it more readable; can be in two independent text files or like this):
el1=element1
el2=element2
el3=somethingelse
el4=andsomethingelsemore
output would be then like this:
element1
element2
element3
element1
element3
How?
TheOm
Post by TheOm »
Combine your condition arrays into a Hash.
Then map the input array to the output using that Hash.
hash.fsm
(459 Bytes) Downloaded 991 times
tester
Post by tester »
Thank you!
