finding elements in range
tester
Post by tester »
Either I'm just tired or tired even more. :mrgreen:
Okay, I'd like to do something in ruby (greenery is too slow for it), and I'm having deja vu, that I asked about it in the past, but can't find it now... So on example:
Inputs:
float (min range)
float (max range)
float array (values to compare with range)
outputs:
array (indexes of values that are in min/max range in relation to base value)
example:
if range is between 95 and 105
and array contains elements:
90
94
98
101
107
110
then on output I'd like to get a list of indexes of values, that fit the range; it would be like here:
2
3
How to make it in ruby?
tester
Re: finding elements in range
Post by tester »
I found only something like this:
output (@in.map {|v| (@min..@max) === v ? v : nil }).compact
but it outputs values, and I need indexes where these values are located.
def event i,v
   a = []
   @f.each_index do |i|
     a << i if (@f[i] >= @min) && (@f[i] <= @max)
   output 0,a
just iterate through the array and compare if value is in range, if yes push index in an array
tester
Post by tester »
Thank you.
One more question. How to combine these two formulas, to have on one output list of indexes and on second output list of values at these indexes?
Basically what I'm trying to do is something like this:
- on two array inputs you connect list of values and list of corresponding names
- on third and fourth input you connect ranges, to see which above values fit them
- and on two array outputs you have list of values and list of corresponding names - that fit these ranges.
then also push the value instead of the index in a second array..
should be something like this (not tested..)
def event i,v
   a = []
         a << i
         b << @stringnames[i]
   output 0,a
tester
Post by tester »
Thanks, I think I solved this one a bit differently
def event i,v
   a = []
   @tones.each_index do |i|
     a << i if (@tones[i] >= @min) && (@tones[i] <= @max)
   output 0,@names.values_at(*a)
   output 1,(@tones.map {|v| (@min..@max) === v ? v : nil }).compact
Seems to work I guess. Now just need to connect somewhere a trigger, to run the operation manually.
tester
Post by tester »
It's rough but it's working. Question: is there a way to optimize it?
def event(in_id, val)
   a = []
   if in_id == "trigger"
Tronic
Post by Tronic »
min = 92
max = 100
f = [90,94,98,101,107,110]
a_idx_in_range = []
a_idx_out_range = []
f.each_index do |i|
if f[i].between?(min, max)
  a_idx_in_range << i
elsif f[i]
  a_idx_out_range << i
watch ' in range' ,a_idx_in_range
watch 'out range', a_idx_out_range
tester
Post by tester »
Hi Tronic! What I basically meant speaking on optimization - is to:
- make more "uniform" the combination of these three operations that are happening in module.
- I have no idea whether what I did - prevents ruby from calculating something even if nothing is sent to outputs (by trigger).
Basically what happens here is:
- one input receives array of names/descriptors
- second input receives array of values that correspond to these names (via the same indexes)
- the rest of inputs is about range
What the module does - is to check which values are within range, and according to that - it sends corresponding names (according to indexes) to second output. Is like this:
example range:
95 to 105
example values:
90
96
100
110
example names:
a90
b96
c100
d110
outputs:
96
100
and
b96
c100
Tronic
Post by Tronic »
min = 95
max = 105
value = [90,96,100,110]
name = ['a90','b96','c100','d100']
a_idx_in_range = []
a_name_in_range = []
a_name_out_range = []
value.each_index do |i|
if value[i].between?(min, max)
  a_idx_in_range << i
  a_name_in_range << name[i]
elsif value[i]
  a_name_out_range << name[i]
watch 'v in range' ,a_idx_in_range
watch 'v out range', a_idx_out_range
watch 'name in range' ,a_name_in_range
watch 'name no range', a_name_out_range
EDIT: schematic in next post :arrow:
