drop list problem.
- Freddymusic
drop list problem.
Hi
When the daw is playing the midi, and plugin is work, the drop list is make a problem if i click on it. Sound will fall silent.
When the daw is stopped it's work perfectly. When i use a simple drop list without any green contact, the bug is still here. I removed the preset menager, and the preset modul, but the bug is here. I'm using SM. I opened it in FS and a replaced the old drop list. Now it's good with the new module, but i want to repair in SM. Is it possible?
freddymusic.hu
- CoreStylerz
Re: drop list problem.
Make sure that preset manager is not set to recompile, kill voices.
PM me if you are interested.
- Freddymusic
- CoreStylerz
Post your osm.
- Freddymusic
When i remove a lot of module, it's work. Somewhere something make this problem. If i can't find it, i will post.
freddymusic.hu
- Walter Sommerfeld
@CoreStylerz:
Man! - where did you get this info from???
I disabled all Modules in my standalone effect because i had dropouts while changing presets...
Only 2 find the Preset Manager is the bad ass...
No doc or Changelist Info about the new Options Input in the Preset Manger: 1=NoMute, 2=NoKillVoices, 4=NoRecompile
1=NoMute did it 4 me
cheers,
Walter
P.S.: Just found out that my Preset Manager Modul in my Toolbox missed the Int 7(default?) in the Options Input...
cheers,
Walter
- Preset Manager Options FAQ.png (28.21 KiB) Viewed 13028 times
wow ... I never noticed this in the manager
now I need to check some of my projects.
