Chronometer
rustyou
Chronometer
Post by rustyou »
Hello,
I'ld like create a stopwatch.
With 2 btn for go and stop chrono.
there is an example ?
CoreStylerz
Re: Chronometer
Post by CoreStylerz »
Only for chronometer?
Just use ruby ticker to 1 sec and you will get 1 tick every second.
Make a counter and set max 60 to get minutes and so on...
Display counter values.
PM me if you are interested.
rustyou
Re: Chronometer
Post by rustyou »
hi CoreStylerz,
Yes.
1 btn for start. and 1 other btn for stop time
rustyou
Re: Chronometer
Post by rustyou »
i am bad with ruby :(
tester
Re: Chronometer
Post by tester »
Check in the toolbox for the ruby module that was described. Using it - does not requires knowing how ruby works.
Re: Chronometer
Post by KG_is_back »
This one uses code counter. start and stop toggle a boolean and that controls a counter within an assembly code. After that the counter is divided by samplerate and you get very precise time in seconds
Chronometer.fsm
(1.96 KiB) Downloaded 883 times
rustyou
Re: Chronometer
Post by rustyou »
Just prefect !!
Thank you KG :) !!!!!!
Re: Chronometer
Thanks KG !!
One for the toolbox ... cause ya just never know ;)
CoreStylerz
Re: Chronometer
I've build a green+ruby ticker chronomater.. 4-5 minutes.
Here is:
Chronometer.fsm
(5.05 KiB) Downloaded 902 times
Ability to start, stop and reset timers.
Also decimals for seconds.
Kg module is ok, but requires audio load.
Re: Chronometer
CoreStylerz wrote:I've build a green+ruby ticker chronomater.. 4-5 minutes.Here is:
Chronometer.fsm
(5.05 KiB) Downloaded 3 times
Ability to start, stop and reset timers.Also decimals for seconds.Kg module is ok, but requires audio load.
Very cool...
Yes you're right about the audio load, but the advantage of my chronometer is, that it is controlled by streamboolean (or defacto by any stream) so it can be sample-precise when triggered by streams.
