Workaround for getting Module Position X / Y
chackl
Post by chackl »
Hello!
I Did a workaround for finding the actual Module Position where the GUI modules are placed with FS
How does it work?
First i switched on mouse-Move operations within the main GUI on the GUI module
Then i get the actual mouse position and send this to the sub modules. i want to locate X and Y.
In every sub module i get the mouse point again - And the difference of the values is the Module X and Y Position. The gag is that the module i want to locate the X and Y position also send mous-move values if i'm outside the module :lol:
Well it is not optimiced - any you may turn off the mouse-Move on the GUI again.
Best Regards.
C.Hackl
modulpos test.fsm
Get Module Position Example
(1.99 KiB) Downloaded 1363 times
