Is there any envelope analyzer made?
djbrynte
Post by djbrynte »
I mean an analyzer there you can see the signal of the envelope.
Like this.
http://howtomakeelectronicmusic.com/wp- ... roller.jpg
I mean there you can see how its drawed.
Xtinct
Re: Is there any envelope analyzer made?
Post by Xtinct »
The multistage envelope has graphic interface or try here
http://synthmaker.co.uk/forum/viewtopic ... dsr#p87479
though the forum is a bit hit and miss loading at the moment.
i did an adsr in ruby which can be setted with the mouse..
viewtopic.php?f=3&t=1756
nix
Post by nix »
I've got an envelope analyser somewhere-will dig it out.
I was using it to build drum synths.
nix
Post by nix »
env analyser.fsm
(244.52 KiB) Downloaded 963 times
djbrynte
Post by djbrynte »
Some how i cant connect the stream even if its same stream as before.
nix
Post by nix »
Try turning the gate off, or triggering the envelope.
djbrynte
Post by djbrynte »
Nope dident solve the problem :/
Jay
Post by Jay »
it wont connect because of the poly analyzer m8! so what you have to do is duplicate your adsr module inside your adsr block and feed the env analyser with a seperate adsr signal!
like this!
env analyser.fsm
(258.15 KiB) Downloaded 980 times
Regards
djbrynte
Post by djbrynte »
Ah ok thnx now i think i got it!
