Examples, Utility Modules, Colorwheel, Analog dial.
BDLutes
Post by BDLutes »
here are a few modules i have found useful in different circumstances.
the analog dial, and colorwheel examples are ones i spent some time putting together.
maybe they will give you some ideas, or provide a few shortcuts.
not really finished, but those examples are working.
https://drive.google.com/open?id=1Ifp8d2JBFKIjJNlkbT-B_VNf6N8WYl0-
Re: Examples, Utility Modules, Colorwheel, Analog dial.
Thaks for sharing that. :D
There's some very useful stuff in there and I would recommend it to others.
wlangfor@uoguelph.ca
Thanks BDlutes, I'll check it out.
My youtube channel: DSPplug
Welcome to the forum, BDLutes!
And what a great introduction; it's always nice to see modules which are not just useful, but also so neatly assembled and presented! The colour wheel in particular is much nicer than the default one - I've always much preferred working with HSV when I'm trying to put a palette together. I was also very taken by your dynamic tooltips which show the current settings of some of the modules. In all my years using SM/FS, I don't think I've ever seen anyone do that before - very handy for debugging, and one of those ideas which seems so simple and obvious the moment you've seen someone else do it first!
BDLutes
Post by BDLutes »
Thanks for checking it out!
If anyone uses it in a project or makes some modifications, share it with me, i'm always trying to learn more. flowstone is an awesome program.
here is another interesting one in mostly ruby code: a slider control, that changes from v to h when it is resized.
https://drive.google.com/open?id=1VBk2oFTf7XuULoS_CXUGrf7rVghyXyHj
BobF
Post by BobF »
Great stuff BDLutes,
Keep up the good work and hope to see more from ya soon!
Later then, BobF.....
Duckett
Post by Duckett »
Oh, these have plenty of "never knew I needed one of those" factor- many thanks!
Thanks BDLutes ... checking them out !
8-)
BDLutes wrote:here is another interesting one in mostly ruby code: a slider control, that changes from v to h when it is resized.
Very clever! :geek:
I didn't get at first that it's the aspect ratio that changes the V to H.
What this needs now is preset parameter integration for the set value...
