Generate Array?
Generate Array?
Ok last question for the day.
What's the best way to generate/calculate an array from scratch, in consistent relation to a function from last entry, or the index # ?
so just..
Designating # of x bins...
entering function (ie x=x+3... or x=index ..or x=index*2+3/4^179)
I'm going for pretty big arrays.....
so just..
Re: Generate Array?
Hi Guy ...
not sure exactly what your looking for ... but posted sometime back, TROG had put together a package of modules called 'TROGS TOOLZ'.
In the 'Auto Numbering folder is an AutoFunction Generator that can generate a variety of Arrays and functions.
not sure if this the latest ... but maybe can help:
- trogz_toolz_v3_1.fsm
- (226.42 KiB) Downloaded 895 times
Re: Generate Array?
guyman wrote:What's the best way to generate/calculate an array from scratch, in consistent relation to a function from last entry, or the index # ?
If you know the size of the array beforehand, the best way is to use its built in method #new:
my_array = Array.new(20) { |index| index*2+3/4^179 }
## creates an array with 20 entries calculated from the code block {}if you don't know the size beforehand you have to append to an existing array, for example:
my_array = []
index = 0
my_array << index*2+3/4^179This will make you happy: https://ruby-doc.org/core-1.9.3/index.html
Re: Generate Array?
Some options for array creation are:
- buildArray3.png (16.95 KiB) Viewed 14013 times
- This one will probably upset tula ...
- buildArray2.png (10.82 KiB) Viewed 14013 times
- buildArray1.png (16.6 KiB) Viewed 14013 times
Re: Generate Array?
It does, Martin, it does. But for a good reason. It's not "the best" way as asked, it's the worst way, because it's not the Ruby way. A for loop is one of the worst methods, especially when doing large arrays, as the op said.martinvicanek wrote:...
But the other methods impress me! I would never had thought about using ASM, that's amazing!
- wlangfor@uoguelph.ca
Re: Generate Array?
i like to build an array, as long as you're sure the index number is accurate there really is no drawback unlike javascript or php.
