Knob ratio : Compressor
Hello !
I have a question,
what is a value of knob ratio (0 - 1) of output : 1:1 ....etc
Exemple knob position 0 = 1:1
knob position (max) 1 = 8:1
How see the reference ??
Thank you
I have a question,
Thank you
Perfect Human Interface
Re: Knob ratio : Compressor
Hello, I'm not sure exactly what you're asking for, but I added an output to my knobs for the 0-1 ratio as well as the set min/max ratio. Maybe something like that will help you? Or you could just set the knob to 0-1 and then multiply by 7 and add 1 outside of the knob.
Hi !
Ex :
How to define three position for my knob :
1:1
2:1
4:1
For this exemple, what is the value for my knob.
limit knob : 0min and max 1
Thx u
Ex :
1:1
2:1
4:1
Thx u
Knob outputs just values, whether these represent ratios or something/anything else. You just set the min/max from 1 to N, and you have ratios, for example from 1:1 to N:1.
If you wish to have specific numbers - you can use a selector driven by knob out or if-then-else routine or some sort of down/up rescaling with integers, if this is supposed to be infinite range of regularly defined ratios.
- ratio2.fsm
- (125.44 KiB) Downloaded 934 times
- ratio.fsm
- (125.37 KiB) Downloaded 900 times
Thank
In out meter monitor.
My compressor will be of knob = 5 --------> out monitor compress = 5:1 value ? exactly ?
- Exemple ratio.fsm
- Exemple
- (13.49 KiB) Downloaded 890 times
Now, connecting second wire to your compressor - remember to scale your green value (on that second wire) appropriately to input requirements of your compressor part, to fit proper ranges there.
Eh ...
For this exemple of compressor.
The value of ratio is : min =0 max=1
What the real value in output (1:1, 2:1...etc)
0 = 1:1
0.5= ?
1=?...
Thank you,
0 = 1:1
0.5= ?
1=?...
Thank you,
- Comp.fsm
- (190.88 KiB) Downloaded 931 times
